It's Happening
The finish of the black stuff
Postby Sandy St. Louis » Thu May 26, 2011 11:15 pm
Sandy St. Louis
Images: 64
Tiny house
Postby Sandy St. Louis » Thu May 26, 2011 11:23 pm
Thanks Droid Good to see another B.C type here there are a few. This is a mini house the other trailer is a vardo project I'm slowly working on and another story. Sandy
Sandy St. Louis
Images: 64
Postby droid_ca » Thu May 26, 2011 11:40 pm
I like the tiny houses I've been wanting one for a while now as in my opinion they have more character then your traditional RV as well as comforts I need to be able to fit a bird cage in my trailer thats 3 feet long by 4 feet tall by 2 feet wide. I'd like to be able to cook inside on bad weather days .plus I was thinking then I could park it in the backyard and possibly rent out my house ok that might be a bit of a dream but I do like them
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby Sandy St. Louis » Fri May 27, 2011 10:04 pm
Droid I don't believe a mini house will replace RV's or travel trailers in fact pulling them at hiway speeds would be very costly something like pulling a parachute. Mini houses shine as inlaw suites, a place for the kids to come back to and still have some independence, a sturdy home for at the lake or rv park for the season and back home or in storage the rest of the time and a great bug out place running from disaster. Shorter ocasional trips would be best for them. Sandy
Sandy St. Louis
Images: 64
Frame changes
Postby Sandy St. Louis » Fri May 27, 2011 10:43 pm
Image Not having a formal plan more tie dows needed to be welded to the frame
Sandy St. Louis
Images: 64
Getting the floor on
Postby Sandy St. Louis » Fri May 27, 2011 10:52 pm
After the holddowns were welded the floor sections were turned over ,joined to each other making one piece and bolted with 3/8 carrige bolts to the frame. insulation was installed and a 5/8 sub floor attached. Where joining is required screws ,glue, staples,and nails are used as required glue always except end grain joints. Sandy
Sandy St. Louis
Images: 64
Insulation
Postby Sandy St. Louis » Fri May 27, 2011 10:56 pm
Sandy St. Louis
Images: 64
We have a floor
Postby Sandy St. Louis » Fri May 27, 2011 10:58 pm
Sandy St. Louis
Images: 64
Framing the wheel wells
Postby Sandy St. Louis » Fri May 27, 2011 11:00 pm
Sandy St. Louis
Images: 64
Wheel wells sheated
Postby Sandy St. Louis » Fri May 27, 2011 11:03 pm
Sandy St. Louis
Images: 64
The start of walls
Postby Sandy St. Louis » Fri May 27, 2011 11:07 pm
Sandy St. Louis
Images: 64
RE: What's in the background?
Postby mezmo » Fri May 27, 2011 11:18 pm
Hi S St L,
Just curious about the Vardo in the background. What's
the story with that?
Looks like you're off to a good start with the Tiny House
build.
Cheers,
Norm/mezmo
mezmo
Images: 194
The Vardo
Postby Sandy St. Louis » Sat May 28, 2011 12:54 am
Norm, The Vardo is a buil I've been playing with for about 6 months I will post a couple of pictures of it on my gallery and may in the future pt a thread on it but this thread is on my building a mini house That being thank you for your interest Sandy
Sandy St. Louis
Images: 64
Back to building
Postby Sandy St. Louis » Sun May 29, 2011 12:33 am
To clear up somethings, being on the downward side of the hill and the very size of this build I am having help with it along with making smaller framing sections. this also increases the number of studs making the building a little over built. Pictures to follow.
Sandy St. Louis
Images: 64
halfway on framing
Postby Sandy St. Louis » Sun May 29, 2011 12:40 am
Sandy St. Louis
Images: 64
