Farmtek Polymax thread Reborn
Postby madjack » Sun Feb 19, 2006 8:54 pm
...thanks for the update...keep us informed..this is interesting stuff................................................ 8)
polymax
Postby Miriam C. » Sun Feb 19, 2006 9:57 pm
:thumbsup: Sid, that looks real good. Could you give us a source for polymax. :) Oh yeah, and a price per sheet. Thanks.
Miriam
Postby gman » Mon Feb 20, 2006 2:44 am
So you could put your lights between the spars,then install the ceiling and have it light up the inside, with nothing to bump your head on? LEDs so you would not have to change bulbs.
Junk is something you've kept for years
And throw away three weeks before you need it.
gman
Postby sid » Mon Feb 20, 2006 9:14 am
Hey Miriam,
It is sold by Farmtek, the link is in the first post of this thread. Here are the prices. If you get thicker than the 1/16th it gets rather expensive, and if you are building a 5 footer, only the 1/16th comes that wide and in a 10 foot length. They ship UPS, and my last order of 4 sheets was around $85.00 and over $30.00 to ship.
PolyMax Board 1/16" x 4' x 8' $18.95 /EA
PolyMax Board 1/16" x 5' x 10' $27.95 /EA
PolyMax Board 1/10" x 47 1/2" x 95 3/4" $29.95 /EA
PolyMax Board 1/8" x 40" x 124" $39.45 /EA
PolyMax Board 1/8" x 47 1/2" x 95 3/4" $36.95 /EA
PolyMax Board 5/32" x 47 1/2" x 95 3/4" $45.95 /EA
PolyMax Board 3/16" x 23 3/4" x 95 3/4" $26.95 /EA
PolyMax Board 3/16" x 47 1/2" x 95 3/4" $52.95 /EA
PolyMax Board 3/16" x 72" x 96" $79.95 /EA
PolyMax Board 1/4" x 32" x 96" $48.95 /EA
PolyMax Board 1/4" x 47 1/2" x 95 3/4" $69.95 /EA
PolyMax Board 3/8" x 48" x 96" $99.95 /EA
PolyMax Board 1/2" x 48" x 96" $139.95 /EA
gman,
It is not that translucent. The lady I talked to at Farmtek had told me light would not shine through it, so I was expecting it to be non-translucent. You can see from the pics that's not the case. But it is not translucent enough to put lights behind.
sid
sid n side
"If you're going through hell, keep going......" Winston Churchhill
Side by Side - completed October 2008
sid
Images: 194
Postby purplepickup » Mon Feb 20, 2006 9:24 am
Volvord 784VC wrote:I hope that this question does not open up another "can of worms" but what is the thermal expansion properties of this product. It is literally indistructable, and even if there is an adhesive that may semi-adhere, it may not lay flat or tend to bubble or shrink depending on the temp.
Just a comment that would be worth investigating prior to using it on a large surface like the roof.
I was wondering the same thing. I know many plastics do expand and contract with temperature changes. I looked up the "Coefficient of linear thermal expansion" of polyethylene and it is quite high. I would expect that if it is firmly attached with screws it might buckle in the heat. Maybe someone could experiment with a sheet by clamping the edges when it's cold then setting it out in the sun to see what happens.
Here's a reference chart http://www.dotmar.com.au/solutions/ther ... ansion.htm
George
purplepickup
polymax online catalog
Postby Miriam C. » Mon Feb 20, 2006 8:37 pm
Thanks Sid,
I went to Farmtek. Interesting stuff. Like the truckliners too. Got different prices in online catalog.
1/16 x 5 x 10 $24.17
1/16 x 4 x 8 15.74
corogated 24.08
Also found tekscrew 100 @ 5.91ea #12 x 1 1/2 (washer or selfwasher)
Joint 2" x 8' 7.95
corner 1.42
thinking that they intend to use the screws but the picture showes rivetted.
To get to the online catalog type in:
Farmtek polymax
Online catalog
polymax board 169
Shipping seems high but looks good.
again, Thanks
Miriam
Postby sid » Sun Mar 05, 2006 11:09 am
Next step will be the exterior Polymax. We got her skinned last weekend, but had to work this weekend. Will give an update when completed......
:D
sid n side
sid n side
sid
Images: 194
Postby chief5 » Sun Mar 05, 2006 12:36 pm
Maybe this has been covered ages ago, but what about contact cement? Is it too brittle? I know it is waterproof when dry and have even seen where canvas was waterproofed with it to make a folding kayak.
chief5
Postby madjack » Sun Mar 05, 2006 12:47 pm
Chief, welcome to the board...Polymax is know as "hi density polyethelene board" and after several emails with several adhesive manufacturers, it has been found that almost nothing will stick toit and that mechanical fastening is required, so Sid and others have been working on a way to float it and seal at the edge with some sort of trim and rubberized adhesives...we all await the results with great anticipation..
madjack 8)
Postby Miriam C. » Sun Mar 05, 2006 5:57 pm
Sid-n-side :applause: :applause: :applause: :thumbsup:
That looks so good I would have a hard time covering it with anything.
ECCO
:...we all await the results with great anticipation..
I am sure it will look good, just want to know if easy.
Miriam
Postby Ron Shaw » Sun Mar 05, 2006 7:40 pm
Sid, yours is looking nice. :lol: I PM,ed you just a few minuted ago before I had a chance to see your pics. Hey looking Guuuuuud :D :D I just want to add this. I too considered the sealing washers, even ordered some. However I beleive, from my little testing efforts, that they will not be needed as the Henrys 663 or the contact cement will hold quite sufficently. I also agree on the use of caulking, IE silicone or Marine Goop, will provide a good and durable seal on the seams when also covered by the aluminum angle. Keep me posted on your progress. We may be on to something big here.... :twisted: :twisted:
Ron Shaw
Teardrop Dreamer
Ron Shaw
Images: 5
Postby Ron Shaw » Sun Mar 05, 2006 7:51 pm
Oh, by the way all, since you "love da pics" I guess I ought to show some of my humble progress. If anyone cares to have a look here are my photos to date. Have not posted the photo with the insulation in place, which is where I am now. Gettin ready to skin this little "Redneck Roadhouse". The pics are here. Do an ascending sort on time and they will be in the correct chronological (did I spell that right) order :D :D
http://tnttt.com/album_ ... ser_id=941
Ron Shaw
Teardrop Dreamer
Ron Shaw
Images: 5
Postby sid » Tue Mar 07, 2006 10:15 am
Sorry MJ, no pics yet, but I skinned the inside of the galley with Polymax yesterday and used the 3M double sided/doublestick tape. You better get it where you want it the first shot, because it ain't coming back off without one helluva fight. I set the first piece a little crooked and well, it's still a little crooked. It was instant bond. It works great, you just have to be sure it's where you want it on the first shot. The edges trim off very nice with a utility knife. I think this is a great alternative for aluminum, especially for folks who have a hard time locating aluminum. It is also much cheaper and can be delivered by UPS. And it comes in a 5 x 10 sheet for you large builders. Farmtek also carries an industrial strength double faced plastic tape (part # LJ7587) for $5.95 per 25 yard roll.
As stated before though, it is not a pristine material. It comes complete with scrathes.
Ron, I'm curious to see how the Henry's 663 works. Let me know. I bought some at HD yesterday, but thought I'd try the tape first. I'm not sure how long the carpet adhesive will stay plyable over the years. With the tape, I don't think it will ever harden.
So far, Polymax is :ok:
sid n side
sid n side
sid
Images: 194
Postby madjack » Tue Mar 07, 2006 10:31 am
Sid, that is good news about the tape :thumbsup: :thumbsup: hope to see pics soon.................................... 8)
Postby sid » Tue Mar 07, 2006 7:40 pm
Hey MJ,
Here's da pics of the polymax on the insides of the galley. I know it just looks like white stuff, but hey, it's the best I could do, and well, they are pics!!!!!
We plan to skin it this weekend.
:twisted:
sid n side
sid n side
sid
Images: 194
