Good thin g is..I'm NOT an idiot..a little cautious maybe, but not off my rocker. So it's carbon MONOxide and yes it IS dangerous.
Jus please be careful peeps !!
canned o minimum wrote:. So it's carbon MONOxide and yes it IS dangerous.
bobhenry wrote:For a couple of years I used a tomatoe juice can with a smaller can dropped inside to raise the coal bed. I think the little squatty can was a beef stew can but I know a la choy chow mein can fits nice.
Got out a can piercer and went crazy around the bottom side of the juice can then pierced holes around the bottom side and the top outer edge of the little squatty can.
I simply dropped the paper in first and loaded the charcoal and lit a small tail of the paper it made a great little chimney !
bobhenry wrote:bobhenry wrote:For a couple of years I used a tomatoe juice can with a smaller can dropped inside to raise the coal bed. I think the little squatty can was a beef stew can but I know a la choy chow mein can fits nice.
UPDATE WITH PICS
mikeschn wrote:Why doesn't anyone use charcoal lighter any more?
It does burn off after the first few minutes ya know, and then it's as clean as if you had used newspaper or similar method...
Mikka wrote:That's what I use...
Mightydog wrote:We don't use a chimney from the store. We use a coffee (large) can like this:
I usually like to put a loop of wire to act like a handle. When the briquets get up to speed, I pull the chimney off using a stick or something mostly fireproof. When the can wears out, we recycle it and start with another. If it gets lost while we're camping, I make another. They're cheap and work like the 'real' ones from the store.
