Guy wrote:When you consider your tongue take a look at the possibility of including a tongue box as part of the structure.
Guy wrote:Also, remember, this is a design for Mike and not those of us privileged to drive without major potholes in California and England. I do not know the last time you drove here but by spring, in Michigan and thirty other states, we have potholes the size of UK caverns on many of our roads. Therefore the twisting moments will be greater than normal.
Guy wrote:As an additional thought, could you please give us a lesson on the real and imagined difference between half torsion axles and full ones. You often write that in Europe half torsion are the norm but we on this side seem to have the same aversion to them as we do for all wood construction rather than steel.
Guy wrote:Whilst I am at it, I wish to add that besides shifting the paradigm from House building we might also consider changing the notion that woody details are merely decoration appliedto the exterior. They should be thought of as more integral to the structural design, sort of , the framing on the outside.
mikeschn wrote:Andrew brought up a good question... how far in does the rubber go? anyone know?
Chuck Craven wrote:Mitheral
That is not good either. The problem is the axel has positive, negative and radial stress all at one point half way down the axel. The axel can amplify that stress point. Two positives or two negative stress points (the wheels) will add to each other at that connection point. The better approach is to have two drawbars mounted near the wheels at an angle to the stress points going to the hitch.
O
| > Put Put
O
Chuck
Mitheral wrote:An A-frame under the torsion box frame connecting the hitch to the axles might be better. Use angle rather than square tubing to reduce mass and the torsion box floor can be bolted to the A-Frame all along it. An additional piece under the front edge of the floor (sort of like the horisontal bar in the A) would allow you to pick up the heavy load of the front wall in a distributed way. A person wouldn't have to go overboard on the angle, even some 1 1/5 sould be sufficient.
Mitheral wrote:No where near the centre. To get an idea look how short the non axle units are.
