CaraWhale
CaraWhale
Postby Perttu » Fri Oct 07, 2011 2:12 am
Hi
I started this thread on Newbies, Introduce yourselves forum, but I continue it here .
I call my van design carawhale – combination of van and punt boat.
It should be ready next spring and I am hoping to do some travel with it on road and on small protected waters.
Trailer might need some kind of winch or trolley - lets see.
I have 2hp yamaha and trolling motor - so I am going to use those. The wooden back grill will be made from 3 parts and one part will be removed when outboard is attached. Outboard can also be fastened to one side while wan is used on land.
Inside bench can be used as table or pushed back "under the back deck" so it would not be on way.
I have starts building and hoping to launch it on spring.
Here some “photosâ€
Perttu
Postby RAYVILLIAN » Fri Oct 07, 2011 7:01 am
Perttu
That is a really great design. I love the way it looks and the way than you have done a cross between a teardrop and a back entrance boat design.
Can't wait to watch you build it.
Gary
111961Image
RAYVILLIAN
Images: 109
Postby StandUpGuy » Fri Oct 07, 2011 7:11 pm
I like it dispite the fact it looks like a whale. The underside of the your design is a legitimate boat hull. Basically it is a pram. It is a matter of taste of course but I say loose the whale and make it look like a slick boat.
StandUpGuy
Images: 52
Postby angib » Sat Oct 08, 2011 8:40 am
I was convinced that there was too much weight at the back with the person and the outboard, so I spent an hour doing some hydrostatic calculations.
This showed that the boat will sit within a degree or two of level, with one person sitting where you have shown. The immersion (depth in the water) to the bottom of the shell would be about 100mm (4") - that excludes the rubbing strips that you have shown below the bottom.
So that proved you were right all along!
angib
5000 Club
5000 Club
Images: 231
Postby Perttu » Sun Oct 16, 2011 12:16 pm
Here is van with side tent. Slowly progress on building. I will post something real next.
Perttu
Perttu
Postby droid_ca » Sun Oct 16, 2011 1:47 pm
Can't wait to see more :thumbsup:
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby Perttu » Mon Oct 24, 2011 12:06 pm
Finally got the side panels ready. Next bulkheads.
Perttu
Image[/img]
Perttu
Postby absolutsnwbrdr » Mon Oct 24, 2011 12:12 pm
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Perttu » Sun Nov 13, 2011 12:55 pm
Got parts ready for assembly :
first front bulkhead
then bow bulkhead
and cabin bulkhead
Last the transom bulkhead. Next some framig and then bottom. I am going to do the bottom finishing and painting at this section so no need to roll the van over again.
Perttu
Perttu
Postby Juneaudave » Sun Nov 13, 2011 12:57 pm
Very cool!!!! Keep those pics coming! :thumbsup: :thumbsup: :thumbsup:
Juneaudave
Images: 380
Postby Greg M » Sun Nov 13, 2011 2:34 pm
I'm loving this build. The whale look is really fun, just look out for harpoons 8)
-Greg
Greg M
*Geek Extraordinaire
Images: 85
Postby StandUpGuy » Sun Nov 13, 2011 8:05 pm
Since the curve of the roof is faily constant why not make the hatch cover slide on curved runners to open it? Then you do not have a hatch in your face while piloting the boat/whale/trailer?
Just a thought. Looks like you are doing nice work. :)
StandUpGuy
Images: 52
Postby StandUpGuy » Tue Nov 15, 2011 7:18 pm
Are you going to fiberglass the hull?
StandUpGuy
Images: 52
Postby canned o minimum » Tue Nov 15, 2011 8:37 pm
Amazing ! Simply amazing ! I imagine it bein backed into the water and released fro the trailer....May yer seas be calm and yer winds favorable !
canned o minimum
Postby Perttu » Wed Nov 16, 2011 12:15 am
HI
I am just going to glasstape the bottom seams - not the entire hull- I am not big fan of glassing. I am allso alleric to epoxy - so I am going to use polyester resin, but the van is moustly staying on the trailer so it´s not big issue.
First I draw the hatch with rails or runnrers, but then thought that it´s better with hinges. The runners need to be quite long and I have to laminate them and then route groove etc. and water would aesyly get trapped between rails.
Perttu
Return to Member Designs
Users browsing this forum: Google [Bot] and 6 guests
