Toilet Vent Question
Postby Tabazooron » Sun Aug 14, 2011 5:11 pm
The "casette toilets" have their own tank, like a porta-potty but they are very expensive and the installation is special!
Different strokes for differemt folks, I guess.
Ron
T@Bazoo
Ron H
Great Lakes Chapter of TearJerkers
Tabazooron
Postby StandUpGuy » Sun Aug 14, 2011 6:51 pm
Mybathroom is all framed out and ready to be plumbed. I have not planned for an internal tank and so there is not room for one to be installed. What I can do is plan for the portable tank and on the trailer toilet main drain put a clean out on one end so if it gets caked up I can still clean it easily. As shown in my very bad paint drawing.
By justoneman at 2011-08-14
StandUpGuy
Images: 52
Postby Ron Dickey » Thu Oct 06, 2011 5:05 pm
Hardware stores may have them for less. HD sells it.
Invented mainly for islands in kitchens that have no place for a vent.
Image[/quote]
if this is out doors already and connecting it to the tank you may want to make sure it is high up so when you roll the tank it does not spill out there. or you could put in a PVC ball valve between.
:cigar: Just remember to reopen it put a note on it saying open when in use.
Ron
121377......134179
Ron Dickey
Images: 711
Postby CarlLaFong » Thu Oct 06, 2011 7:50 pm
StandUpGuy wrote:Mybathroom is all framed out and ready to be plumbed. I have not planned for an internal tank and so there is not room for one to be installed. What I can do is plan for the portable tank and on the trailer toilet main drain put a clean out on one end so if it gets caked up I can still clean it easily. As shown in my very bad paint drawing.
The toilet that you have drawn will not work. When you go, errr......doo doo, it will sit right where it lands. Trust me, it does not, as the old adage says, roll downhill unless you have the digestive system of a goat. It will take a great deal of water to flush everything towards the portable tank, something that an RV toilet cannot do. This is why, when you camp where there are hookups and you have a regular black water system, you do not leave the gate valve open. You open it when you're near full so the accumulated liquids will wash out the tank as it rushes out. If you just leave it open, all the poop will sit at the bottom of the tank, the liquids will trickle out and you will have a real mess to clean out later.
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Postby StandUpGuy » Sun Oct 09, 2011 7:33 pm
Then how do people use these wheeled black water tanks?
StandUpGuy
Images: 52
Postby StandUpGuy » Sun Oct 09, 2011 8:28 pm
That makes sense to me. You got your poo and you have your near horizontal pipe. Seems like a problem.I could probably eliminate any horizontal at all. It would be less convienient to attach everything.
By justoneman at 2011-10-09
StandUpGuy
Images: 52
Postby CarlLaFong » Sun Oct 09, 2011 9:07 pm
That'll work. It may be a bit more difficult to hook up. If the toilet is against an exterior wall, you can leave your flex line long enough to connect it to the tank and then roll it under the trailer, allowing the flex to collapse until you have a straight shot from the pot to the tank
CarlLaFong
Images: 5
Postby StandUpGuy » Sun Oct 09, 2011 9:19 pm
CarlLaFong wrote:That'll work. It may be a bit more difficult to hook up. If the toilet is against an exterior wall, you can leave your flex line long enough to connect it to the tank and then roll it under the trailer, allowing the flex to collapse until you have a straight shot from the pot to the tank
The outlet straight down from the toilet would only be about 16" from the side of the trailer. Not too bad really. I do not have experience in using any RV type toilets just a marine toilet in a sailboat I used to own, so I appreciate the feedback.
StandUpGuy
Images: 52
