fornesto wrote:If there is concern about the wood being sealed, couldn't you use house wrap over the insulation (on the cabin side) to prevent interior moisture from getting up into the insulated area? This would effectively create a dry zone if done correctly.
Mitheral wrote:fornesto wrote:If there is concern about the wood being sealed, couldn't you use house wrap over the insulation (on the cabin side) to prevent interior moisture from getting up into the insulated area? This would effectively create a dry zone if done correctly.
House wrap allows water moisture to pass thru while keeping out liquid water. You would want to put a vapour barrier on the humid side of the wall to keep moisture from settling in the walls.
I doubt moisture from the inside is what causes travel trailers to rot out though, gross water leaking in from the outside and soaking framing members seems much more likely, especially on a unit with no bathroom.
Micro469 wrote:What's a bathroom got to do with it?
fornesto wrote:IMHO, I was thinking of the humidity created by two warm bodies inside of the tear. Putting the barrier facing down would prevent that humidity from getting in the hollow cavity. I believe the humid side of the wall to be the inside. I might of done this had I thought of it ahead of time since I don't have a roof vent. Gross water leakage is bad, but the death of the original teardrops was from inside humidity rotting outward, from what I hear.
Dean in Eureka, CA wrote:From what I've read about insullating the walls and the roof, about making sure there are no voids of air left inside the insullated cavity...
Am I correct to assume that the wood srfaces of the studs and plywood skins need to be sealed as well?
Another way of wording my question... Should the insulation be glued into place, using the glue also as a sealant... Or should the wood surfaces be sealed first, then use a tight dry fit piece of insulation in the cavity, or glue it into place into the sealed opening?
