How I built a penny stove the easy way
Postby BigAl » Tue Dec 06, 2011 10:06 am
Hi guys, I know many of you are also hikers and thought you might appreciate this entry on my blog.
Kind Regards, BigAl.
Build Journal on T&TTT
BigAl
Images: 29
Postby rich5665 » Tue Dec 06, 2011 10:22 am
Thanks. I never thought to use a full can. :DOH2: Your idea should save me a couple of nicked fingers the next time I make one of these.
rich5665
Postby BigAl » Tue Dec 06, 2011 10:43 am
Yes, the full can gives the rigidity to press fit them together, and not pushing two cans cut edge to cut edge together makes for less hassle.
BigAl
Images: 29
Postby hoytedow » Tue Dec 06, 2011 2:25 pm
That's a great device and so is the potholder.
Happy trails,
Hoyt
hoytedow
Images: 19
Postby BigAl » Tue Dec 06, 2011 2:33 pm
Thx! :D
BigAl
Images: 29
Postby kirkman » Tue Dec 06, 2011 2:36 pm
That is my go to stove when backpacking! The thing I like about them is there is nothing that can go wrong with it it lights and works all the time!
kirkman
Images: 55
Postby hoytedow » Tue Dec 06, 2011 3:14 pm
If you heat the partial before you quickly slide the well chilled full can into it, would that make the assembly easier?
Happy trails,
Hoyt
hoytedow
Images: 19
Postby BigAl » Tue Dec 06, 2011 3:24 pm
Yes it probably would, however the walls of a drinks can are so thin that you will easily push one can into the other provided you drill the pressure vent hole first.
Maybe some WD40 lube would also help?
BigAl
Images: 29
Postby iwannagofishin » Tue Dec 06, 2011 3:36 pm
Thanks for showing this. I'm definitely going to give this a try.
Can you please explain the priming and starting again? Prime with the coin, then remove the coin? Ouch.
iwannagofishin
Postby BigAl » Tue Dec 06, 2011 4:24 pm
Good point, I skipped through the whole priming thing at speed.
I have updated part two of the blog post with a bit more priming detail and I have replaced the priming video.
Here is a pic, as I know you guys are addicted to pictures. ;)
BigAl
Images: 29
Postby iwannagofishin » Tue Dec 06, 2011 5:04 pm
Awesome. Thanks again.
iwannagofishin
Postby hoytedow » Wed Dec 07, 2011 7:26 am
iwannagofishin wrote:Awesome. Thanks again.
Ditto.
Happy trails,
Hoyt
hoytedow
Images: 19
Postby bonnie » Wed Dec 07, 2011 7:46 am
Okay. I've never seen one of these penny stoves, so bear with the questions.
How do you store it if it still has fuel in it?
How do you extinguish it? Blow like a candle?
Looked very interesting and useful.
Bonnie
Remember, the turtle won. :)
bonnie
Images: 107
Postby hoytedow » Wed Dec 07, 2011 7:59 am
Extinguish it by placing an inverted mug on it. If any remaining fuel it won't be much.
Happy trails,
Hoyt
hoytedow
Images: 19
Postby BigAl » Wed Dec 07, 2011 2:17 pm
Hi Bonnie, When I have finished using the stove, I wait until it is completely cool, then I tip the remaining fuel back into the fuel bottle. The stove drains readily through it's burner holes and any residue left in the stove evaporates.
A good blow usually put's it out, or snuffing as hoytedow suggests.
BigAl
Images: 29
Users browsing this forum: No registered users and 29 guests
