Treeview wrote:Why not use a pressure cooker to heat water and cook?
I've seen cook time studies on lightweight backpacing forums that show how using a pressure cooker saves time and fuel. The fuel savings off sets the added weight in a lightweight cook kit. when you're chasing grams it's easy to find the benefits.
eamarquardt wrote:[It just which is the "lesser" evil.
warnmar10 wrote:Air is less dense at altitude so, all else being equal, more air must pass through the system to support the same intensity of combustion at altitude as at sea level.
Treeview wrote:eamarquardt wrote:[It just which is the "lesser" evil.
Or...as Captain Jack Aubrey says, 'The lesser of two weevils'
http://tinyurl.com/Jack-Aubrey-weevils
The key is "all else being equal". Essentially it is unknowable unless we can compare equal fuel sources at sea level and 10k or whatever. If it turned out to be a problem I think I would just adjust the fuel, but that's me.Treeview wrote:warnmar10 wrote:Air is less dense at altitude so, all else being equal, more air must pass through the system to support the same intensity of combustion at altitude as at sea level.
Yup...I learned that in high school physics...but...at what elevation does it make a difference in campfire heat?
My guess is that there is way more O2 in the air up to an elevation approaching 10k feet or so that is needed. At some elevation the needs of a woodfire are going to suffer...but, would that even be a consideration?
Users browsing this forum: W3C [Validator] and 8 guests
