Okay... I haven't posted any pictures/progress for a while, but I made some waves in March. We had a week of "summer" weather in Vermont, before I had to go back to stoking the wood fire in the shop.
Before I could varnish the exterior, I wanted to put some black epoxy trim on the door cutout:
Then, I lined up the sides and doors and gave them 8 coats of Epifanes High Gloss Extra UV-Filter Varnish -- 5 spray coats and 3 hand coats with them laying flat.
I bolted the floor to the chassis (with a little layer of rubberized ice flashing material in between), and took a break in our 80 degree March weather in VT!
Friday, March 23 was the BIG DAY! ASSEMBLE!!!
My Neighbor Andy, and two friends, John and Charlie, from my men's group gathered at 9 AM to help me attach the sides to the floor.The sides were all set:
And the Crew was ready:
Andy, testing the glue gun:
Glue in the groove. This is right out of
Steve Fredrick's Shop Manual. Highly Recommended!!! The 1 3/8" wide groove in the wall slides over the 1 3/8" thick floor for 1" above the floor, and 3/4 below, and fits flush against the sides of the chassis. A nice tight fit that gives the wall a lot of stability.
Both walls in place now, with one of the bulkhead also glued in place in the pre-routed grooves. Andy's steady hand to run a screw through the floor down into the 1x3 in the wall below (without going through the exterior!)
A little joking around... it was a fun morning.
Testing out the length:
THANKS CREW! GREAT JOB! **********************************************************************************
My crew left me to begin fussing around with the cabinetry -- which is what I've been doing ever since -- gluing and clamping little sticks together, trying to keep it lightweight, functional, and yet smart-looking. We'll see....
The Galley begins:
Add some insulation:
I need to complete the inside first so that I can do the varnish, then put on the roof. (After that, I can build the Hatch Cover and after the Hatch Cover I can do the Galley cabinets.)
Lots of clamps:
I have another day's work to do on the interior cabinets, plus 5 cabinet doors for the interior. Plus I need to figure out the interior outlet and switch holes in the side walls ( I wanted to cut them before the walls got vertical, but ran out of time before assembly day) But soon.... I'll be ready for the headliner, and some roof insulation. Stay tuned...
Ken
