droid_ca wrote:Mike good question,
Can this be trimmed down with a router bit or do you have to have it exact before you glue it,as I'm thinking this might be good for my sleeper idea
(temporary thread jack) I priced out sleepers from this place in the states and starting price was 1800 bucks then I'd still have to modify it for what I want and shipping was a fortune....ok back to Mikes thread
halfdome, Danny wrote:I found trimming with a 1/2" flush trim bottom bearing bit that it's too fast and will melt the aluminum.
A Freud 42-118, 3/4" flush trim bottom bearing bit slows it down and it cuts like butter .
It has a 1/2" shank so you'll need a 1/2" Colette if your router doesn't have one.
Danny
eamarquardt wrote:halfdome, Danny wrote:I found trimming with a 1/2" flush trim bottom bearing bit that it's too fast and will melt the aluminum.
Danny
I'm confused (which isn't a new thing). A 3/4" bit will have a higher speed at the cutting edge than a 1/2" diameter bit. Do you slow down the router with the 3/4" bit.
Thanks,
Gus
mikeschn wrote:Danny,
That 7/8's inch molding looks wonderful. Very classy!
Is that the standard way of doing aluminum, or are there other methods?
Do you have a closeup of your edge molding that goes between the wall and the roof?
Also, do you have a close up of your molding where you hide the horizontal wall seam?
Thanks,
droid_ca wrote:Is that molding pliable as I have an idea where there are a few curves do you just anneal it with a torch and it gets work hardened as you bend it...am I on the right track?
