Sheet plywood weight and questions
Postby Rob Dines » Mon Apr 03, 2006 8:51 pm
Does anyone have weights for sheets of plywood? 1/4", 1/2", and also 3/4". Need this to get my overall weight so I can design the frame. Either sq. foot or sheet weight is good. Anyone have a good 1/4" exterior skin suggestion as ply is sorta expensive if exterior.
Thanks..
Rob
Rob Dines
Postby Chris C » Mon Apr 03, 2006 8:59 pm
There have been many discussions concerning this matter. I just did a Search on "weight of plywood" and got this one: http://tnttt.com/viewto ... 26&start=0
Do a search and you will probably find a whole lot more info.
Chris :D
Chris C
Postby mikeschn » Mon Apr 03, 2006 9:21 pm
Rob,
I use this rough guesstimate...
3/4" plywood is 75#
1/2" plywood is 50#
1/4" plywood is 25#
You can extrapolate the rest...
Images: 479
Postby madjack » Mon Apr 03, 2006 9:42 pm
mikeschn wrote:Rob,
3/4" plywood is 75#
1/2" plywood is 50#
1/4" plywood is 25#
...me too, me tooooo(as he butters up da boss).................................................... :lol: 8) :lol:
Postby mikeschn » Mon Apr 03, 2006 9:46 pm
Hmmm...
smells like buttered popcorn from the theater around here... okay... who dun it? :lol: :lol: :lol:
Images: 479
Postby madjack » Mon Apr 03, 2006 9:50 pm
:shhh: :whistle: :roll: :MLAS :lol: :lol: :lol: ............................... 8)
Postby GPW » Tue Apr 04, 2006 7:59 am
Since you've given away the secret of Guesstimating Ply , how about telling us this .... That GVW thingie , that's including the weight of the trailer too that the cabin /TD sits on ,right ???? Those trailers have to be heavy , no ???
Postby mikeschn » Tue Apr 04, 2006 8:20 am
Yep, all weights include the chassis...
More info...
Net carrying capacity (NCC) determined by subtracting unloaded vehicle weight (UVW) from gross vehicle weight (GVWR) and includes fluids, options and cargo.
Images: 479
Postby cracker39 » Tue Apr 04, 2006 9:16 am
BUT...those weights are general guidelines and will vary with moisture content, type of wood in the ply, etc. I thought my 3/4" BC plywood for the floor felt heaver than 75 lbs, so I weighed it...87 lbs. It is made from yellow pine, which is heavier than spruce.
Dale
cracker39
Images: 233
Postby madjack » Tue Apr 04, 2006 10:20 am
cracker39 wrote:BUT...those weights are general guidelines and will vary with moisture content, type of wood in the ply, etc. I thought my 3/4" BC plywood for the floor felt heaver than 75 lbs, so I weighed it...87 lbs. It is made from yellow pine, which is heavier than spruce.
...that is why they were refered to as "guesstimations"..................................... 8)
Postby cracker39 » Tue Apr 04, 2006 12:28 pm
madjack wrote:...that is why they were refered to as "guesstimations"..................................... 8)
Hmmmm..."guesstimation"... that sounds a lot like a SWAG.
Dale
cracker39
Images: 233
Postby madjack » Tue Apr 04, 2006 3:29 pm
...absolutely the same thing :D ....................................... 8)
Postby angib » Tue Apr 04, 2006 3:36 pm
I see you Merkans still use the easy abbreviations.
The max weight of a British caravan (trailer) is its MTPLM - Maximum Technically Permissible Laden Mass!
And its 'empty' weight but with any options fitted is its MIRO - Mass In Running Order.
I think these are probably both Yurpeen terms, but decided on by non-English speakers - Yurp does have about 25 languages........
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby cracker39 » Tue Apr 04, 2006 4:04 pm
There are other quaint mercun acros that would apply to my build. So far, I've run up against situations best described as SNAFU, SUSFU, FUMTU, FUBB, TARFU, TOFU, but as of yet, I haven't made it to FUBAR, and hope I don't get that far.
:worship:
Dale
cracker39
Images: 233
