One last little addition. I purchased this panel for the new trailer, but since that is not ready, it will be used for this trip.
80 Watts of power, should keep me topped off with my minimal use of electricity.
ieheg2 wrote:Paul, what you want to connect to a solar panel? Or just charge the battery ...
Irving wrote:What type of body filler did you use for this build? Also what was it that you coated the underbody with? Very well made travel trailer. Just browsed through the whole thread. How has your acrylic enamel finish been holding up?
parnold wrote:Irving wrote:What type of body filler did you use for this build? Also what was it that you coated the underbody with? Very well made travel trailer. Just browsed through the whole thread. How has your acrylic enamel finish been holding up?
Honestly I don't remember what brand body filler I used. I just grabbed a damaged can from our defect room and used that since it was free. Probably a U.S. Chemical or Fibreglass Evercoat filler (lightweight). The undercarraige was done with Evercoat 1348 aerosol undercoating, and the paint is holding up fantastic. My only error was not taping the joints with fiberglass tape before the polyester resin was applied.
I am very happy with how it's holding up.
