by Q » Thu Sep 15, 2005 8:35 pm
Looks like it's got a 4 amp 12V charging circuit. That's not a lot. For faster charging I would suggest a small gasoline engine coupled to a standard automotive alternator. A small Honda 4 stroke engine can be had for under $200 and a used alternator can be had for $20. Add a few bucks for a belt, pulley, and frame and you have a light weight generator that can charge at 25 to 100 amps depending on horsepower.
I have one that I use around the house that consists of a 5 hp Honda engine $160 new from eBay, 6" pulley $6 from hardware store, used alternator from an old Ford (free), V belt $3 from auto parts store, homemade frame from 1" square steel stock, and a piece of nichrome wire for the field resistor. I also added a larger muffler that I had laying around the house. It's very quiet, uses very little fuel, and puts out 65 amps.
Q
