do i need to use the 16-2 wire in the generic benroy?
Postby bronco » Fri Jul 21, 2006 1:51 pm
in the plans it says to run 16-2 sound cable to all light locations and the fan but i bought 14 gauge 12 volt wire for those locations. is that going to be o.k.? or do i need to use the 16-2 for a certain reason?[/img]
bronco
Images: 31
Postby bledsoe3 » Fri Jul 21, 2006 2:24 pm
Bronco, That should work fine.
bledsoe3
Images: 112
Postby madjack » Fri Jul 21, 2006 3:39 pm
Bronc, it basically never hurts to run larger wire...we basically used 14ga wire for all our hook ups with the exception of the power in leads from the battery to fuse block where we used 10 ga......
Postby GeorgeTelford » Fri Jul 21, 2006 5:39 pm
Hi
For a Fan and Lights I would consider 14 AWG to be the absolute minimum, personally I would use 10 AWG
I hate voltage drop, its a waste of power and causes waste heat.
Overdoing the wire costs next to nothing in weight or money and saves you power in every use. (I dont really consider it as Overdoing it, to me its doing the Job right)
BTW sound (twin) wiring underates the wire even further 16-2 is under size for a fan and lights, this underating is further exacerbated by the fact that the wire is buried
GeorgeTelford
Postby Chuck Craven » Fri Jul 21, 2006 8:59 pm
There is a wire chart: take a look in the part 2 section.
http://www.ccis.com/home/mnemeth/12volt/12volt.htm
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby bronco » Fri Jul 21, 2006 10:05 pm
thanks for the advice and also the link to all of the electrical info that will definately help. thanks again!!!
bronco
Images: 31
Postby GeorgeTelford » Sat Jul 22, 2006 4:42 am
Hi Chuck
The chart on the second page is an excellent guide
GeorgeTelford
Postby TD4FREEW/CTD » Sun Jul 23, 2006 10:56 pm
just make sure your circuits are run with wire that is adequate for whatever you overcurrent rating is. that is, providing you are using overcurrent devices!
TD4FREEW/CTD
Postby TomS » Mon Jul 24, 2006 5:58 am
I ran 12 guage wire in mine.
TomS
Users browsing this forum: Bing [Bot] and 1 guest
