Popping Breakers - Safe Shore Power
Postby Dale M. » Mon Aug 07, 2006 3:28 pm
I was reading another message thread on "popping breakers" and it occurred to me that though whole discourse that nobody mentioned checking "shore" power outlet before "plugging in" either at home or away.
Seems to me that people would WANT to know if shore power was safe before connecting...
This simple tool would verify shore power before you plugged in and would go a long ways to insure your connection and appliances inside may be safe.
And they are NOT really expensive....
Dale
Dale M.
Images: 18
Postby Chris C » Mon Aug 07, 2006 3:34 pm
You are definately correct, Dale. :thumbsup: That is a helpful little device. It has been mentioned within many threads, so would probably be hard to find. Good to bring it up to everyone's attention once again, though. :applause:
Chris :D
Chris C
Postby PaulC » Mon Aug 07, 2006 5:18 pm
Okay Dale, so what's it called. Can't see too many going to the local big box and asking for that "doovalacky" thing for checking voltage :lol:
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Location: Laura, Souther Flinders Ranges, South Australia
Postby Dale M. » Mon Aug 07, 2006 7:14 pm
Oops!!!!.........
Its a RECEPTACLE TESTER.....
IT comes in two versions... One "standard" and one with push button for testing GFI receptacles and breakers...
Here is where I lifted graphic from....
http://www.proskit.com/cgi-bin/proskit/ ... d=UsP8VLp5
Dale
Dale M.
Images: 18
Postby Steve_Cox » Mon Aug 07, 2006 8:07 pm
Dale,
I've got a reverse polarity tester you would really like. It is built into my electrical panel and if there is a problem with the power source the main breaker will trip and not reset. It also has a red LED to tell you about the reverse polarity condition.
Steve_Cox
Images: 196
Postby Dale M. » Mon Aug 07, 2006 9:52 pm
Actually I was not thinking beyond a extension cord for battery charger....
Shore power where I camp would require about a 15 mile extension cord...
Which brings up another question!... Is your cord for shore power rated big enough to actually carry the load your "system" is wired for....
Was in hardware store today and happened to look at a 50 ft. 12 gauge 3 conductor cord, it was rated at only 15 amps.... What is your cord rated at?
Dale
Dale M.
Images: 18
Postby RKH » Tue Aug 08, 2006 8:22 am
Thanks, Dale. Just bought 2 of them. (You working on commission? :lol: )
~Keith
Support Our Troops
Our traveling blog is at http://www.Happy-Tracks.com
RKH
Images: 16
Postby Dale M. » Tue Aug 08, 2006 11:48 am
RKH wrote:Thanks, Dale. Just bought 2 of them. (You working on commission? :lol: )
Nope.... Worked in a industry that required every receptacle we installed to be tested when done... Learned to believe in them.... Just for **giggles** you may want to test receptacles in your house and garage...
Dale
Dale M.
Images: 18
