I want to build an Ultra-Light Teardrop.
Postby Gerdo » Tue Aug 29, 2006 11:39 am
I'm starting to think about building a second TD. This time I'm thinking of an ultra-light. Who has built one? Who has pictures/designs? What does it weigh? What would you change?
Gerdo
Images: 156
Postby Steve Frederick » Tue Aug 29, 2006 11:46 am
Is #740 light enough?
Peg's is a 4-by-8, sandwich construction, light frame, torsion axle..
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby mikeschn » Tue Aug 29, 2006 12:22 pm
I take it you've already checked out the Ultralight Design thread from top to bottom?
http://tnttt.com/viewto ... ultralight
Images: 479
Postby Gerdo » Tue Aug 29, 2006 1:15 pm
Mike
I searched for an article like this but could not find it. Still reading. Thanks.
Chris
Gerdo
Images: 156
Postby rmcelroy » Tue Aug 29, 2006 1:49 pm
I was dissapointed-I took mine to get it weighed and it came in at 560 lbs. I had hoped for about 400 to 450. But it still pulls pretty well.
It will be awhile but I may consider a second effort in the future.
Left out things like
12v battery pack
3/4" plywood galley cabinets
Propane tanks
Excessive frame work
Included
Aluminum frame
1/4" luan interior cabinet work
I will be trading my full torsen axle for a pair of shorties-which should get me down about 45-50 lbs.
I didn't have the cofidence to go really radical with hollow core door floor and cabin frame with 1/8" luan skin w/o aluminum, or all wood frame construction. There are some really creative folks here.
Mc
Wheather you think you can or you think you can't, your right.
Henry Ford
rmcelroy
Images: 27
Postby Gerdo » Tue Aug 29, 2006 2:23 pm
Mike
I just finished reading the 15 pages on Ultralights. How is yours coming. Did you go with a straight tongue or an A frame? Did origimaly think of incorporating the HF frame into the floor (use the metalframe instead if wood sandwich)?
Gerdo
Images: 156
too light
Postby jay » Tue Aug 29, 2006 3:28 pm
don't confuse "creative" with, err, "not practical"
jay
Postby mikeschn » Tue Aug 29, 2006 4:07 pm
Gerdo wrote:Mike
Gerdo,
It's still on the bench in the basement. I had designed it to be 4' wide, andhalfway thru the build I decided I really want it to be 5' wide. I'm not sure the design is capable of 5'.
So it's sitting down there, as a future project.
Meanwhile, I've built the Escape Hatch/Winter Warrior which I designed a couple summers ago, and now my thoughts are turning to a more fully featured Winter Warrior. Meanwhile I want to do up a set of plans on ebay to increase the traffic here, plus I have a whole lot of CAD work I want to do.
But I have to agree with Jay. Creative is not always safe. I would definitely bounce any ideas off of Andrew before taking an untested concept on the road.
Images: 479
Postby apratt » Tue Aug 29, 2006 7:23 pm
Mike, I can't see where there be any problem in making the ultralite into a 5 foot wide trailer?
Arthur,
ASL spoken here
apratt
Images: 16
Postby mikeschn » Tue Aug 29, 2006 8:09 pm
apratt wrote:Mike, I can't see where there be any problem in making the ultralite into a 5 foot wide trailer?
Arthur,
A couple problems come to mind, not all of which are design related...
1) The HF axle is set up for a 4' wide trailer
2) The sides are made out of 5mm luan. Is that strong enough for a torsion box, or do I need to have 1/4" baltic birch, with it's many layers?
I imagine if the torsion box is strong enough, and the axle is wide enough, and the floor is stiff enough, then it shouldn't be a problem.
Andrew, go ahead and take my theory and smash it to pieces! :BE
Images: 479
Postby apratt » Tue Aug 29, 2006 8:56 pm
Sorry Mike, in my mind I changed a few things....
1) not use H/F axle, buy an axle kit to the width I need.
2) go with 1" frame and 1/8 panel for the walls.
3) use the A frame set that Andrew showed.
Arthur,
ASL spoken here
apratt
Images: 16
Postby Roly Nelson » Thu Aug 31, 2006 1:33 am
Gerdo, use a 40" x 48" HF frame, (150 Lbs) and build the 6 foot wooden teardrop using a 1 3/8" hollow core door for the floor, 1/4" sidewalls and 1/8" roof. All of this wood, with basic shelves and cabinets in the galley will only weigh 95 lb. I know, I did it and the TD only weighs 245 lbs.
Roly :thumbsup:
Roly Nelson
L'il Ol' Woody Builder
what an i missing?
Postby jay » Thu Aug 31, 2006 4:54 am
i understand "light" - but what is the purpose of "ultra-"?
tow by bike or human powered craft?
jay
Postby angib » Thu Aug 31, 2006 9:07 am
I can't either. The only things that the extra width affects are the roof spars and the floor.
As I remember the Ultralight has a single skin roof, so the strength of the roof spars is quite important. On a 5ft span, even close-spaced 1x2s (with the 2 vertical) sounds a bit weak to me, but 1x3s sounds over the top, so maybe it's 1x3s cut down to 3/4"x2" actual.
As the floor is a sandwich panel, I don't think the 5ft span is any problem - Mike drew 1/4" ply top and bottom which I think is probably overkill! My only concern would be the point load on the front of the floor if a single tongue is used - using a piece of oak (of the same size) instead of softwood would address that.
I can't see any problem with the axle on a 5ft wide - except that you can't use a HF trailer kit. Either torsion or leaf spring would do, though I would have a preference for torsion as it provides a strong cross-member for free.
On the subject of the axle, I have now seen a couple of places where it clearly shows that in full-beam torsion axles, the rubber goes nowhere near the middle, so Mike's original idea of welding a single tongue to the middle should work fine - though as I mentioned before, I guess you can kiss goodbye any warranty on the axle. I still prefer an A-frame for the lower load it puts on the body.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Gerdo » Fri Sep 01, 2006 9:31 am
Roly
Can you post any build descriptions and pictures so I can see how you kept the weight down. I don't want to over build but I also don't want to under build it and have it flimsy. I would hate to see it blow apart on the highway.
Gerdo
Images: 156
