Fuse panel Vs. Direct Wire
Postby Jst83 » Tue Aug 29, 2006 10:04 pm
I'm about to start wireing my tear. I don't plan to have battery. I was wondering is there a real need for a fuse or breaker panel or can I direct wire it all to the cord to the campground electric. Hope this makes since :?
Jst83
Images: 215
Postby Dale M. » Tue Aug 29, 2006 10:17 pm
I personally think you need to have some sort of protection for your internal systems. That means a breaker panel or fuse panel with at least one breaker or fuse (or how ever many be required) between your trailer systems and shore power... IF you power needs are minimal one circuit with 15 amp breaker or fuse may be enough ..
You can never be sure what shore power you will be plugging in to and how well it is protected... It may have a amperage capacity that is high enough to cause damage in your system before "their" breaker blows...
Dale
Dale M.
Images: 18
Postby bdosborn » Tue Aug 29, 2006 10:25 pm
I get to look at all kinds of electrical systems with my work. Some of the scariest I've seen have been at campgounds. You should protect the hundreds of hours you'll have building your trailer with a circuit breaker. There's plenty of people here who will talk you through the install.
Images: 456
Postby asianflava » Tue Aug 29, 2006 11:29 pm
At the very least you could do a setup like Mike's. A GFCI power strip that plugs into the pole, then everything is plugged into that.
asianflava
Postby emiller » Wed Aug 30, 2006 6:32 am
The worst thing in the world would be to have a fire in your trailer when your asleep, always when safety is in question be safe add some sort of protection.
emiller
Images: 157
Postby mikeschn » Wed Aug 30, 2006 7:16 am
We added a $5 smoke detector to our Winter Warrior. 8)
Images: 479
Postby Jst83 » Wed Aug 30, 2006 2:21 pm
Looks like a breaker system is the way to go. Time to find a small breaker box. Thanks everyone for keeping me from takeing the short cut I new I shouldn't take. :oops:
Jst83
Images: 215
Re: Fuse panel Vs. Direct Wire
Postby Steve_Cox » Wed Aug 30, 2006 7:32 pm
How about a ground fault interrupter to plug into the campground power and then a power strip or two with a pop out breaker in the TD.
Jst83 wrote:I'm about to start wireing my tear. I don't plan to have battery. I was wondering is there a real need for a fuse or breaker panel or can I direct wire it all to the cord to the campground electric. Hope this makes since :?
Steve_Cox
Images: 196
Postby mikeschn » Wed Aug 30, 2006 7:38 pm
Agreed...
If you can slip a gfci in between the campground power and your trailer, you don't need a fusebox/panel...
Images: 479
Postby TomS » Wed Aug 30, 2006 7:56 pm
mikeschn wrote:If you can slip a gfci in between the campground power and your trailer, you don't need a fusebox/panel...
Mike, posteth electrical blasphamy! You needeth both GFCI and a breaker sayeth the Lord.
GFCIs and breakers serve two completely separate functions. GFCI's keep you from being electrocuted. Breakers protect your tear from fire. I use a short GFCI 3 outlet cord in my tear. My extension cord has a built-in 15-amp breaker.
As others have stated, do not trust campground wiring. Carry your own GFCI and breaker protection.
TomS
Postby mikeschn » Wed Aug 30, 2006 8:02 pm
Okay I stand corrected.
I stated early on I know very little about electricity... That's why we have guys like you to save our teardrops!
Images: 479
Postby Larwyn » Wed Aug 30, 2006 8:13 pm
I used both. A breaker box and GFCI outlets, put them together in a compact package, from there it is simple outlet strips for those things with plugs............. :D :D
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby bdosborn » Wed Aug 30, 2006 8:37 pm
Steve_Cox wrote:How about a ground fault interrupter to plug into the campground power and then a power strip or two with a pop out breaker in the TD.
Yup, that's the ticket for people who want to keep their wiring simple and sweet. Plug 'em in and you're done.
Images: 456
Postby Endo » Wed Aug 30, 2006 8:45 pm
You can pick up one of these at Lowes (Shock Buster). It has a built in GFCI and a 15 amp breaker.
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby Jst83 » Thu Aug 31, 2006 5:12 am
:? Seems to be quit the difference of opinion. GFCI or Breaker. Where is the best place to pic up a small breaker. I'm going to visit the local junk yard Fri. they have a couple nice campers I've been pilfering parts off of. Gonna see what they have going to also get my water inlets for the camper.
Jst83
Images: 215
