Different grades of aluminum?
Postby sean » Thu Aug 31, 2006 11:55 am
I want aluminum top and sides for my teardrop. What thickness should I use? Does it matter what grade I use?
I am looking at a metal supplier website
http://www.factorysteel.com/aluminum-angles-bars-channels-pipe.htm#d
I see
3003-H14
5052-H32
5052-O
6061-T651
6061-T4
6061-O
2024-T3/351
2024-O
7075-T6
7075-O
Will any of these work? Should I just go with whatever grade is cheapest?
sean
Postby coreyjhen » Thu Aug 31, 2006 12:09 pm
I won't bore you with a lecture on metallurgy, but here's a good site: http://www.ez.org/aluminum.htm. I'm using 5052 H32 and definitely would avoid the 6000 and 7000 series. They are much harder alloys and are more difficult to work with. In fact, our robots use 6061 T6 for the chassis and 7075 for the track frames - and they are built to crawl the walls inside power plant boilers.
"They laughed at Columbus, they laughed at Fulton, they laughed at the Wright brothers. But they also laughed at Bozo the Clown." - Carl Sagan
coreyjhen
Images: 9
Postby alaska teardrop » Thu Aug 31, 2006 12:49 pm
    Sean,
    I'll second Corey on the 5052-H32. It will give you good corrosion resistance on those nasty Michigan winter roads! :lol:
    .032" or .040" if you are backing it up with plywood on the roof. Thicker, if you're not.
alaska teardrop
Postby kerryd » Thu Aug 31, 2006 1:33 pm
Sean , I also use alot of5052 H32 and 3003 H14 . I like the first better . 6061 T6 they shove iron in it so it don't really bent , more of a braker Kerry
kerryd
Postby kerryd » Thu Aug 31, 2006 1:43 pm
Hey Sean , I just looked in my book , 6061 is kind of a special order type thing , at less with suppliers I know . The 3003 and the 5052 comes in 48 or 60 wide ,and 96 , 120 , or 144 long
kerryd
Postby asianflava » Thu Aug 31, 2006 2:01 pm
I used whatever was alailable. When you start talking about 5ft wide rolls, you have to take what you can get.
asianflava
thanks all
Postby sean » Thu Aug 31, 2006 9:29 pm
Thanks for the quick reply. That's really useful to know. I am going to build a 5' wide and might have to take what I can get, but that gives me a good starting point.
sean
Postby sean » Fri Sep 01, 2006 2:19 pm
good link Coreyjhen. I knew there had to be a method to all those numbers.
sean
