Benjamin Moore epoxy
Postby Woodbutcher » Thu Sep 28, 2006 9:46 pm
Has anyone used Benjamin Moore epoxy coatings. I was thinking of using their epoxies as my exterior finish. I am doing a Benroy style and was going to paint the roof and clear finish the sides. The spec sheet sounds good. I talked with the paint store manager and he said it would work great. But then again he sells the stuff. Not always the best guy to ask. //tinyurl.com/zddbo
Woodbutcher
Postby madjack » Thu Sep 28, 2006 11:46 pm
WB, most any 2-part outdoor rated epoxy should work OK...and the BM fits those paticulars just fine......... 8)
Postby Woodbutcher » Fri Sep 29, 2006 7:30 pm
Thanks Madjack, picked up the BM paint today, the clear comes in next week.
Woodbutcher
Postby Endo » Wed Nov 08, 2006 2:53 pm
Woodbutcher wrote:Thanks Madjack, picked up the BM paint today, the clear comes in next week.
Which epoxy did you purchase?
Is it this one:epoxy
Have you applied it yet? How do you like it?
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby Miriam C. » Wed Nov 08, 2006 8:19 pm
If it is this one, it is acrilic epoxy and water clean up. It is not the same as marine epoxy. It also doesn't say a thing about UV resistance in the initial read (Endo's URL). :roll: You might want to read carefully before you use it.
Sorry
Postby Woodbutcher » Wed Nov 08, 2006 9:05 pm
The Black I used was DM74/DM75 Industrial coating. The clear I used was was Polyamide Epoxy 36/37. I was told the clear has UV protection the Black does not. The BM salesman said to put 2 coats of black on and then finish with a coat of clear over it. Both were very easy to use. I applied them with a small foam roller. Left some orange peel. I scuff sanded between my first a second coats. Sands real easy. I still have to put the woody trim on. I will sand again before the final coat. I may try spraying the final coat to reduce the orange peel. Heres where I am so far.
Woodbutcher
