sealing walls????
sealing walls????
Postby blk05m6gto » Wed Oct 11, 2006 10:25 am
Hello all, I am about to lay out the walls..... I was wondering what everyone has done to seal their walls... Do I paint/epoxy before i attach them or is it ok to do after Im all done? I am building in my garage so it will never see the elements till it is all done..... Just wondering what you all think. Thankx Bill
blk05m6gto
Images: 25
Postby asianflava » Wed Oct 11, 2006 2:13 pm
My trailer was pretty much all put together before I applied the polyurethane, though I removed cabinet doors, drawers, vent fan, lights, etc. I started with a brush but it was a pain to use under the interior cabinets and the ceiling. I eventually used a spray gun.
asianflava
Postby BrwBier » Wed Oct 11, 2006 4:04 pm
Any painted parts on my trailer have all 6 sides painted. It was a PITA getting all the parts painted when I really wanted to be putting them together, but years from now I hope I will be happy with my decision.
Brwbier
BrwBier
Images: 100
Postby NightCap » Thu Oct 12, 2006 11:35 am
I am building an all wood TD so epoxy will be a must for me. I went looking for some epoxy and found some in a boating store for almost $100. There has to be a cheaper place to find it. Let's hope epoxy is epoxy. Marine grade might be a better product. Who knows?
#1 - 100% Done #2 - 100% Done Thinking about #3
NightCap
Images: 259
Postby K-1 » Thu Oct 12, 2006 11:41 am
NightCap wrote:I am building an all wood TD so epoxy will be a must for me. I went looking for some epoxy and found some in a boating store for almost $100. There has to be a cheaper place to find it. Let's hope epoxy is epoxy. Marine grade might be a better product. Who knows?
Look here for Marine Epoxy at a cheaper price :thumbsup: -Wayne-
http://boatbuildercentral.com/products.php?cat=41
You can get 3 gallons for $ 147.00 you most likely will use more than you think.
K-1
Postby Miriam C. » Thu Oct 12, 2006 12:19 pm
I cut my sides, glued the frame down then covered everything that wasn't getting glue with some floor finish I had laying around (6gals laying around only used 1 1/2) 8) If water gets in it will need to find a new place to go.
Nightcap,
Marine epoxy is different from the poly and may be worth the extra. There seems to be some debate over that one. :D
Postby K-1 » Thu Oct 12, 2006 1:20 pm
Polyester resin is not water proof, epoxy is. -Wayne-
K-1
Postby srfrcrux » Thu Oct 12, 2006 1:45 pm
What do you need to use to seal an all woody TD? :thinking:
Adopt a Drop or be board to tears!!!!
www.myspace.com/thelains
srfrcrux
Postby asianflava » Thu Oct 12, 2006 3:02 pm
K-1 wrote:Polyester resin is not water proof, epoxy is. -Wayne-
Yes, don't confuse the two. Polyester is a lot cheaper than epoxy but it isn't as durable.
asianflava
Postby Arne » Thu Oct 12, 2006 3:52 pm
I would seal the walls as soon as they are done to prevent warping..
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby srfrcrux » Wed Oct 18, 2006 12:19 pm
Ordered 3 gal on epoxy resin 350/127 non-blushing :oops: from Raka today....excellent service!!! $159...(i.e. Steve Frederick and other thread recommendations).
Awesome!!!
We'll see how it does, eh?
srfrcrux
/what about epoxy for all exterior surfaces prior to skin
Postby jdjernigan » Wed Oct 18, 2006 7:10 pm
Has anyone epoxied the completed exterior prior to skinning with aluminum? Can you still use adhesives to hold the aluminum in place until the trim is on? What type?
Joe
jdjernigan
Images: 7
Postby steve wolverton » Wed Oct 18, 2006 7:37 pm
srfrcrux wrote:Ordered 3 gal on epoxy resin 350/127 non-blushing :oops: from Raka today....excellent service!!! $159...(i.e. Steve Frederick and other thread recommendations).
Awesome!!!
I've done business with them for years and have always had good luck with their products, and their advice.
Just don't mix too much at once if it's warm outside, it will kick off quicker than you think. It's best to mix small batches at a time.
Also, there is very little smell - I actually built a boat inside my dorm with the stuff in winter. No problems. *twitch* *spaz* *foot shakes*
�veni, vidi, vici.�
steve wolverton
Images: 11
Re: /what about epoxy for all exterior surfaces prior to ski
Postby asianflava » Wed Oct 18, 2006 8:18 pm
jdjernigan wrote:Has anyone epoxied the completed exterior prior to skinning with aluminum? Can you still use adhesives to hold the aluminum in place until the trim is on? What type?
Joe
I did, I'm glad I did because I brought it out camping in that state. It rained and rained that weekend. All was fine, I only did one coat but it was fine. Still had a slightly rough feel to the surface so I think there was enough "tooth" for the glue to hold down the aluminum.
asianflava
Postby jdjernigan » Thu Oct 19, 2006 5:47 pm
Asianflava,
What type epoxy did you use? Was is thinned? Thanks!!
:thinking:
Joe
jdjernigan
Images: 7
