Final Schematics! Please have a look!
Postby alexgray104 » Thu Nov 02, 2006 1:12 pm
Hello,
Spent the last week or so planning the electrical system in my tear, I'm planning on installing the 12vdc myself, but the 240v Mains will be installed by a professional, who will also have a look at my 12v system and make sure it is correctly connected. The final (i hope!) schematics is below. Please note the trailer lighting system will be on a different system powered by the car, which I plan to keep completely seperate from the tear electrics, unless I install a "S" socket for charging the tear on the move. Any comments you have with it would be appeciated.
Thanks to the designer of the original plan - much appreciated. I have also put in a distribution box to simplify things a little.
Thanks Alex.
(edited) Schematics:
alexgray104
Postby asianflava » Thu Nov 02, 2006 2:20 pm
Looks good to me. You may want to add a 12V outlet in the cabin. I usually use mine for a plug in reading light.
asianflava
Postby NightCap » Thu Nov 02, 2006 2:47 pm
asianflava wrote:Looks good to me. You may want to add a 12V outlet in the cabin. I usually use mine for a plug in reading light.
One in the kitchen for keeping the cell phone on the charger would be convienient.
#1 - 100% Done #2 - 100% Done Thinking about #3
NightCap
Images: 259
Postby asianflava » Thu Nov 02, 2006 3:22 pm
Yup, you're right. I looked at the schematic and knew that one was missing, when I clicked over to post reply, I forgot which one. It's the galley outlet that you are missing. You are already installing a mains in both places, why not put a 12V outlet (or two) there also.
asianflava
Postby alexgray104 » Thu Nov 02, 2006 3:34 pm
Yeah I agree, the original galley 12v outlet was modified into the 12v Pump power socket and I forgot to put the galley sockets back on!
I actually planned on charging mobile phone on a small shelf on the front wall, along with storage for watch, wallet etc...
see pic if you don't understand what i mean....
(bearing in mind no measurements set out yet, so pic not to scale)
alexgray104
Postby Chuck Craven » Thu Nov 02, 2006 7:16 pm
alexgray104
The one thing I would change is to move the battery charger “red +” wire between the master on off switch and the master fuse! Just in case the charger would get a short will driving down, the road the fuse will protect the charger from starting a fire. :shock:
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby Chuck Craven » Thu Nov 02, 2006 7:20 pm
OOPS saw one other thing! You need a safety ground for your 240 v ac outlets! :o
Chuck
Chuck Craven
Images: 62
Postby Miriam C. » Fri Nov 03, 2006 1:47 am
The other thing you might consider is putting another GFCI Before the charger. You can plug your charger in instead of hard wiring it. Have it next in line after the main breaker and everything downsteam from there.
Looks good.
Postby alexgray104 » Fri Nov 03, 2006 11:34 am
Thanks for your replies everyone,
Miriam C - I did think about this once I'd published your thread and thought it might be easier.
alexgray104
Postby Miriam C. » Fri Nov 03, 2006 1:54 pm
Chuck Craven wrote:OOPS saw one other thing! You need a safety ground for your 240 v ac outlets! :o
Chuck
Yep! Need that third line going back to your main ground lug. Usually green or bare here. ;)
Postby alexgray104 » Mon Nov 06, 2006 6:34 pm
Please see edited schematics :) :)
alexgray104
Postby Miriam C. » Mon Nov 06, 2006 7:43 pm
:applause: Looks good to me.
The new plug for the charger, is it to be GFCI? Doesn't have to be just one of my pet likes.
Postby asianflava » Wed Nov 08, 2006 1:27 am
I'd try to put the galley and cabin outlets on separate circuits. Why? because you never know what you are going to plug into one of them. You may need to plug in one of those 12V heaters which will pull down some big time amps. If you have them wired separately, it will essentially double your current capacity to that outlet.
asianflava
No battery install
Postby Creamcracker » Thu Nov 16, 2006 8:01 am
I thought I saw the schematics set up for wiring the TD without a battery/charger -- was I dreaming 'cause I can't find it now? Can anyone point me in the right way?
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby Miriam C. » Thu Nov 16, 2006 8:21 am
Philip,
Follow this thread to #2 and down to Joanne and Kerry's diagram. One of them should get you there.
