DO table
DO table
Postby rmcelroy » Sun Dec 03, 2006 12:05 pm
Not so much of a construction question as a what do I need-or is this a good idea question.
I purchased a rail that will allow me to attach/detach a table to the side of my tear. I plan on some kind of metal top (probably alum square tube) and I have very light weight small table I plan to rob a set of folding legs from-all in the pursuit of a DO cooking table.
Weight is a premium for me so I don't want to just buy a prebuilt table to haul around.
I don't have a lot of DO experience, so thought I would ask the experts, what are the major considerations here?
Thanks all
Its good to be around rational folks again-I've been off visiting football boards for awhile
Wheather you think you can or you think you can't, your right.
Henry Ford
rmcelroy
Images: 27
Postby TomS » Sun Dec 03, 2006 12:43 pm
I wouldn't use aluminum for your DO table surface because it has a low melting point. Steel, although heavier is a far better choice.
Also, you might consider using a free standing DO table because you can reposition it depending upon how the winds are blowing at the time. This has two advantages.
1. Wind is no friend to the DO chef. Wind blows the heat away from your pot and causes uneven cooking. You want to position your table so that the wind screen blocks the wind, or place the table behind something that will block the wind for you.
2. It's also nice to position the table the smoke is NOT blowing in your face. This happend to us at Cape Cod last year. We simply picked up the table and moved it 10 feet.
I have the Campchef DO table, I paid aroung $70 for it at Cabelas and it doesn't weigh that much.
TomS
Postby apratt » Sun Dec 03, 2006 12:53 pm
Or you could use the 'Volcano'. Can use that on any surface and not burn it. Also use it as campfire pit or grill with it and the best of all use it for your D.O. . http://www.volcanocorp.net/
Arthur,
ASL spoken here
apratt
Images: 16
Postby asianflava » Sun Dec 03, 2006 2:05 pm
For an 8" or 10" DO you could probably use a cookie sheet and just lay it on the ground. If you mount a table to the side of the trailer, it will have to be sturdy to handle the weight.
asianflava
Postby dwgriff1 » Sun Dec 03, 2006 2:13 pm
I carry a 12" square ceramic tile (Home Depot: 99cents) to put pans and stoves on (I use single burner stoves). When it breaks, I'm out a whole buck.
Works on wood table.
dave
dwgriff1
Postby surveytech » Sun Dec 03, 2006 4:48 pm
Purchased a new cookie sheet for the house and use the old one under the dutch. works just fine especially when place on the firering grate.
or go fancy and get a plow disk and attach some removable legs so you dont have to bend over so far. (offical old fart tip)
surveytech
Images: 6
Postby Ma3tt » Sun Dec 03, 2006 5:13 pm
Plow disc on a dumpster find patio table stand works great and the table stand acts like a safety barrier. and yeah thick cookie sheets work well too I got one from Smart and Final
Be Good
1967 Siesta del Sobrino "Standy"
If you lived here... you would be home by now.
http://www.Camp-Cook.com
Ma3tt
Dutch Oven GURU
Images: 179
Postby surveytech » Sun Dec 03, 2006 7:31 pm
Matt you ARE the man.
remote thermometer?........high tech DO cookin'
how cool is that?
surveytech
Images: 6
Postby KA » Sun Dec 03, 2006 8:40 pm
Hi Apratt,
That Volcano looks like a neat thing. Thanks for the tip.
Kris 8) :)
KA
Images: 9
Postby apratt » Sun Dec 03, 2006 9:47 pm
KA wrote:Hi Apratt,
Kris 8) :)
You are welcome. I have used mine now for about 5 years, it has been great. One time I had chilli cooking and had it in the back of the truck going to a picnic. So I was making dinner while I was driving. :lol: :lol: Now I am looking for bbq lid that will fit on top so I could smoke meat in it, then it be perfect.
Arthur,
ASL spoken here
apratt
Images: 16
Postby bledsoe3 » Mon Dec 04, 2006 11:54 am
We I was at the IRG the DO expert suggested using a metal oil changing pan (upside down). I found one at GI Joe's for less than $10. I've had a 12" DO on it and it worked great.
bledsoe3
Images: 112
Postby Mike B » Mon Dec 04, 2006 4:51 pm
I use on of these for Dutch oven cooking:
<img src="http://www.campchef.com/includes/image.php?image=ct32lw.jpg&dir=/sites/campchef/images/products/&width=200&height=200">
The legs come off, which reduces the table height to about 10". The windscreen comes off, too. I pack the whole thing in the back of my car or inside the TD. Camp Chef - about $90.
Mike
Hayden Lake, ID
Mike
Hayden Lake, ID
Mike B
Postby Loader » Mon Dec 04, 2006 4:59 pm
Mike B wrote:I use on of these for Dutch oven cooking:
Mike
Hayden Lake, ID
I use the same thing, picked it up at Cabela's think I paid about $70 for it. Works great.
Earl & Kerry
"Loader"
Loader
Images: 245
Postby asianflava » Tue Dec 05, 2006 1:36 am
I've got the same one, I got it at Sportsman's Warehouse.
asianflava
Postby Dennis T » Tue Dec 05, 2006 7:01 am
We also have the table. Bought it this year and we love not bending over to the ground anymore. It can be located anywhere on your campsite, holds four DO's, (at least that is what we have put on it), and I like shopping at Cabela's. The other ideas suggested were great also. Cookie sheet......dang that's great.
Dennis T
Dennis T
Images: 10
Return to Cast Iron
