Moderator: Sonetpro
system-f wrote:Here are some pics of the coupler I made for my offroad utility trailer before the trailer box was finished.
The pins on the hitch were welded tight and the clips removed for safety. This mount provides no isolation between trailer and tow vehicle.
system-f wrote:I find it very disrespectful when people make comments about something someone has created on pictures (not to mention crappy pictures taken in the dark) alone rather than asking more questions like, how thick is the steel, how good are your welding skills, what is the strength of the center bolt.
Think about your response and how I might be a little butt-hurt. Did you ask about chains? I could have (and do) have chains that bypass this hitch just in case. This is a normal occurrence on most bulletin boards and is rather disheartening.
This hitch has been thoroughly tested beyond the limits of most 'rated' hitches with no failure or signs of stress.
