1200 Watt gen for $199
Postby dhazard » Sun Mar 11, 2007 10:38 pm
Has enyone tried this generator? 1200watt 1500 peak, $199.
page two of the add.
http://kragen.inserts2online.com/custom ... oreID=4077
http://www.cpeauto.com/generators.htm
Many miles and many tears. Times were hard but now they're changing.
You should know that I'm not afraid.
dhazard
Images: 122
Re: 1200 Watt gen for $199
Postby Geron » Mon Mar 12, 2007 5:22 am
DHAZARD wrote:Has enyone tried this generator? 1200watt 1500 peak, $199.
Couldn't find much googling. Here's a owner review.
http://www.rv.net/forum/index.cfm/fusea ... 825963.cfm
Geron
Images: 173
Postby dhazard » Sun Mar 18, 2007 8:06 pm
Nobody had anything bad to say, so I picked one up on Friday. So this is a quick little review. It comes with the 12 volt adaptor cable, and a small funnel. Added oil and gas to it, moved the choke to on, pulled the rope and it started on the 1st pull :phew: . It can run my 5000 BTU AC with no problem or the 600 watt Microwave, but not both. The startup surge from the AC does cause it to stumble for a second or two, but it recovers fast. The microwave startup is a little easier for it even thought it has a higher wattage rating, less startup surge. Now for the noise, it is about the same as a lawn mower, maybe a little quieter, but not much. My trailer has a cover for the generator that I will line with sound foam, and I have added a pipe to the muffler to get the exhaust out of the compartment. The pipe and the cover do help quite it some. The generator has a 12 volt DC out that I will use that to power two fans to help cool the case. For now I give it a :thumbsup: :thumbsup:
dhazard
Images: 122
Postby Miriam C. » Sun Mar 18, 2007 8:56 pm
:NC You are going to keep it in the tear at night, runningImage
Oh grasshopper Image
Postby dhazard » Sun Mar 18, 2007 9:28 pm
This is the cover for the generator and AC with a little room leftover for storage. I’m to lazy to take it out so I built it in. I try and a good neighbor and keep things quiet, that why it’s in a sound insulated box. But if you want I can get a long extension cord and put it next to your trailer. :R
dhazard
Images: 122
Postby Miriam C. » Sun Mar 18, 2007 9:39 pm
DHAZARD wrote:Image
Oh goodie. I'll keep the camera ready. :lol: My paranoia showing huh. You can park next to my trailer anytime. 8)
Postby bledsoe3 » Mon Mar 19, 2007 1:04 am
Do you have it vented so the A/C cannot draw any of the exhaust from the generator?
bledsoe3
Images: 112
Postby dhazard » Mon Mar 19, 2007 8:18 pm
The top sides of the box on have vents and I will add 12 volt fans to blow the heat and fumes out. To let fresh air in the bottom of the box is expanded metal. I have also added a pipe to get the exhaust out of the compartment. Also the AC only pulls air from inside the trailer so no exhaust fumes should get sucked into the trailer.
dhazard
Images: 122
Postby bledsoe3 » Tue Mar 20, 2007 12:24 am
I didn't know if the AC would bring in any fresh air to mix with the recirculated air.
bledsoe3
Images: 112
Postby Arne » Tue Mar 20, 2007 6:53 am
Thinking about a generator, can a 1k generator run a pet cool??? meaning, can it handle the start up surge draw?
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby bledsoe3 » Tue Mar 20, 2007 6:55 am
I think Bruce has a 1K Kipor that runs his pet cool. I'm sure he'll respond.
bledsoe3
Images: 112
Postby asianflava » Tue Mar 20, 2007 7:20 am
Steve (Sonetpro) has the Petcool 1K Kipor setup too. I have the 5Kbtu window shaker and a 2K Kipor.
asianflava
Postby bdosborn » Wed Mar 28, 2007 10:48 pm
Yes, the 1000w Kipor will power the Petcool. I have my Kipor up for sale on ebay. I picked up a 1000W Yamaha that I like better. Quieter and handles large loads better.
On the cheaper side of things I ran across this low priced generator website on a big RV site:
http://www.duropower.com/index.asp?FID=2&level=1
Don't know anything about them though...
Images: 466
Postby Elumia » Wed Mar 28, 2007 11:52 pm
Isn't that yamaha the same one that is offered in a propane version? I bet they have a conversion kit if you were so inclined.
Mark
Elumia
Images: 15
Postby bdosborn » Thu Mar 29, 2007 7:24 pm
Elumia wrote:Isn't that yamaha the same one that is offered in a propane version? I bet they have a conversion kit if you were so inclined.
Mark
Yeah, I'm kind of interested in that. It would be nice not to have to mess with gas. On the other hand, gas is a lot easier to find then propane.
Images: 466
