My wiring plans
My wiring plans
Postby Joanne » Thu Jan 20, 2005 12:25 pm
Hi all,
I've been thinking about how to set up the wiring systems on my trailer. I've broken the wiring up into three systems; the trailer running lights, the trailer battery charging circuit, and the cabin lights.
Here are the three diagrams that I came up with. Any comments, suggestions, or thoughts about what I've laid out?
Thanks!
Joanne
New! My Camp Cooking Forum
Project Desert Dawg website
Universal Health Care
Joanne
Queen of Cast Iron
Re: My wiring plans
Postby angib » Thu Jan 20, 2005 1:09 pm
Joanne wrote:Any comments, suggestions, or thoughts about what I've laid out?
How about a master on-off switch - in my experience, even if you switch off all interior lights and double check that you've done so, they just switch themselves back on again when your back is turned.....
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby shil » Thu Jan 20, 2005 1:19 pm
I concur. Add a master on/off switch and a master fuse, in line between the battery and the fuse block.
shil
Postby bdosborn » Thu Jan 20, 2005 3:12 pm
Joanne,
Here's a link to a sketch I did showing wires sizes and fuse sizes. Add that to your diagram and it would be a great tool for everybody. I think Mike was looking for something like this.
http://home.comcast.net/%7Ebdosborn/tea ... iagram.pdf
Images: 466
Postby asianflava » Thu Jan 20, 2005 3:57 pm
Those are the prettiest schemtaics I've seen in a long time.
asianflava
Postby AmyH » Thu Jan 20, 2005 4:15 pm
I have to agree Joanne, those schematics are gorgeous! :thumbsup:
Amy
Amy
"...follow humbly whereever and to whatever abyss Nature leads, or else you shall learn nothing." T.H. Huxley
Photo Log
Camping Trips with the Tear
AmyH
*The 300 Club
Postby Steve Frederick » Thu Jan 20, 2005 5:16 pm
Joanne, POY-FECT!!!Want a job??? 8) By CAD guy in my office doesn't do as nice a job. :thumbsup: His are boring B/W. I agree with the master switch idea. You can get one that clamps on the battery positive post. I have a circuit-breaker in the line from the alternator to the trailer. It's a 30 amp unit from the parts store.
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby Guest » Thu Jan 20, 2005 6:00 pm
That's very nice Joanne!!!
Guest
Postby Lone Wolf » Thu Jan 20, 2005 6:15 pm
I've said it before and I will say it again the people on this board are some of the best thinkers there are around. One thing I would add to charging circuit is a battery automatic isolator so if you forget to turn switch off it will not run your tow battery down. They are usualy installed on trailers with liftgates to keep batterys charged.
HAPPY TRAILS
Lone Wolf
Images: 6
Postby mikeschn » Thu Jan 20, 2005 6:26 pm
Very nice Bruce,
Thanks for sharing! :)
bdosborn wrote:Joanne,
Images: 479
Postby gardenwood » Fri Jan 21, 2005 12:09 am
Nice work! :applause: Any chance of getting the two schematics posted as a sticky for those of us who'll need this help in the future? Thanks in advance if this can be done.
Roger and Lois
gardenwood
Postby Guest » Fri Jan 21, 2005 1:46 am
Roger and/or Lois,
I just tried to capture that pdf sketch with screen hunter to do that for you but I see that you can't scroll down with that item, you can only capture what is shown on your monitor. Screen Hunter is the only tool that I have found that will change a pdf file into an image.
Maybe Mike knows a different way to post Joanne's images and also show Bruce's pdf file as an image at the same time in the same post, or maybe we could get Joanne to list the wire sizes in her drawings.
Guest
Postby Joanne » Fri Jan 21, 2005 8:07 am
Thanks all!
I'm really glad that I have been able to make a contribution back to this great group of folks who have given me the encouragement to build my own trailer!
I will revise the drawing to include a master fuse and master cut-off switch. I will also touch base with Bruce to see if we can calculate the appropriate wire sizes and fuses.
I'll be in Reno/Carson City most of next week so it may be a early next week before I have it all completed.
Joanne
Joanne
Queen of Cast Iron
Postby Joanne » Fri Jan 21, 2005 8:13 am
Lone Wolf wrote:One thing I would add to charging circuit is a battery automatic isolator so if you forget to turn switch off it will not run your tow battery down. They are usualy installed on trailers with liftgates to keep batterys charged.
Hi!
If I understand your post correctly, I think I have it taken care of. The solenoid is normally open, but held closed by the toggle switch AND the ignition switch in series. Even if I forget to turn the toggle switch off, removing the key from the ignition will isolate the trailer battery. (I never leave my keys in the ignition.)
Joanne
Queen of Cast Iron
Postby Joanne » Fri Jan 21, 2005 8:22 am
Hey Bruce!
Would you assist me in calculating the appropriate wire and fuse sizes? I don't know the current draw for each of the electrical devices I've identified. I looked at your drawing but wasn't sure if my devices would have the same draw as the ones in your schematic.
Between us we should be able to improve the drawings and make them more useful for everyone.
Thanks in advance.
Joanne
Joanne
Queen of Cast Iron
