Porch light
Porch light
Postby asianflava » Tue Feb 08, 2005 2:58 am
I'm planning on buying these lights. Does anyone have these fixtures? I was wondering what type of bulb it uses? I want to buy an LED replacement bulb for it.
asianflava
Postby exminnesotaboy » Tue Feb 08, 2005 7:50 am
12v type 1003
the numbers on the bulb itself: 100312v15cp.taiwan
exminnesotaboy
Postby mexican tear » Tue Feb 08, 2005 9:35 am
That is the same light I have. I also have the same light on a "big" trailer. It has worked well for years.
kai
"Essie" and the Mexican Tear
mexican tear
Images: 14
Postby asianflava » Tue Feb 08, 2005 3:14 pm
Thanks X-MN-boy! That's exactly what I need.
asianflava
Postby norm perkiss » Tue Feb 08, 2005 10:36 pm
I'm using the same one. They are used on all the Coleman tent trailers. I've replaced the original bulb with leds from SuperBrightLeds web site. The 24 light unit was not bright enough for me, bought the 36 light unit (1156-PCB-W36 White LED Lamp) . I attached the circuit board with several layers of double sticky foam tape. I may go back and use some silicon chalking instead. The led light cost 3 times the price of the light fixture. I'm also using the 36 led light in the dome light.
Norm
Current Draw @ 12VDC:
24 LED - 85ma
36 LED - 123m
norm perkiss
Images: 62
Postby asianflava » Tue Feb 08, 2005 11:28 pm
That's where I saw that porch light, on the Coleman popups. I was going to use the exact same LED setup. Thanks for the heads up on the 36LED unit. I wasn't shure which one to go with. I was worried that the 36LED unit wouldn't fit and was seriously considering the 24LED unit.
Thanks again!
asianflava
Postby Eric Adams » Sun Feb 13, 2005 10:58 pm
Who sells these??? :D
Eric Adams
Postby asianflava » Mon Feb 14, 2005 2:03 am
asianflava
Postby asianflava » Mon Feb 14, 2005 7:48 pm
asianflava
Postby exminnesotaboy » Mon Feb 14, 2005 11:39 pm
asianflava wrote:I ended up buying these:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4516497404&category=50070&sspagename=WD1V
Saved a couple bucks.
asianflava
I bought the same ones from the same eBay guy - quick shipping, good packaging - everything went smooooooooth :thumbsup:
exminnesotaboy
