Here's how I did it...and maybe some tips will help. First off...your ribs need to match the profile (and make allowances for the sheet goods that will be covering the hatch)...and there are a lot of ways to do that...
You can cut a rib template from a master...you can steam bend around a form...you can scribe..
The main thing is to get the shape correct. As far as materials, ply works well...in my case, I used steam bent ash around a form. On this pic...notice that I have a good solid header to mount the hinge on...
The best advice I heard was to not over think hatch construction and build it in place. That way it will fit for sure. When framing in place..I left a spacer block of 1/4 inch between the header and the hatch to fit the hinge in.
Another tip to a really solid hatch is to use good construction. My bocking is glued in with a dado...I think those kreg pocket screws would work wonderful...
From then on...take er off...finish it like you like it...
Mount the hatch back on...and she fits!!!!
