The scenic II.. (Last update --April 9, 2010) Hatch Struts
Postby john » Sat May 02, 2009 11:55 am
I welded up the frame last month and was able to start the working the wood last week.
It will have a couch/bed and two roll away canvas cots in the front (cots similar to my first build) above the couch. I need room for the three kids. I also will give them each a window.
There is also a larger bed for my wife and myself toward the rear.
I simply could not give up an exterior galley in the rear.
so....
Frame
Upside down
Driver's side (inside)
Driver's side (outside)
Passenger Side (No door.....yet)
Spars in and fantastic vent and sunroof fitted
As of yesterday...Bulkhead and bed frame
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby Miriam C. » Sat May 02, 2009 12:10 pm
:thumbsup: :thumbsup: :applause: Great progress. I like the windows. The kids should love that! Are they arguing about who gets the top yet. :D
Postby john » Sat May 02, 2009 12:20 pm
Two pushing for the bottom! :shock:
Penomeli ikibobo
john
john
Images: 261
Postby teardrop_focus » Sat May 02, 2009 12:33 pm
I viewed with intense interest, my good man, the pics of your tear build. The tear turned out nicely; it's a beautiful little trailer.
This, though... this is OFF THE HOOK. :applause:
Love the grooved paneling, too. Very nice! :thumbsup:
teardrop_focus
Images: 127
Postby northern_munkie » Sat May 02, 2009 3:35 pm
Ohhhh :o
Me like...... :applause:
Im not as think as you drunk i am!!!
northern_munkie
Postby caseydog » Sat May 02, 2009 3:40 pm
Very Nice. I'd like to do a standie, but I need to keep it low enough to go in my garage.
It looks like yours will be good looking. :thumbsup:
My build journal is HERE
caseydog
Images: 515
Postby john » Sat May 02, 2009 5:08 pm
Thanks guys.
How high is a standard garage? 7'?
I'm a shade over 7' now with the bow in the roof and the stabilizers nearly lifting the camper off the ground. If I try I can rotate the tires. I had intended lowering the swing arms but after the weight is on the suspension I may not need to. Also I had initially intended to build a slouchie (spelling?) but it became clear while laying out the sides that I needed the 6" for the triple bunk in the front. I'm trying to avoid submarine "bunks".
There was no flow in the building process today, but by picking up a little frustration in exchange I pushed through it . I got a little done but all in all it was not a productive day. Picks later.
Penomeli ikibobo
john
john
Images: 261
Postby mikeschn » Sat May 02, 2009 5:10 pm
Looking good. I like the interior wood...
What is the exterior going to be?
Images: 479
Postby Senior Ninja » Sat May 02, 2009 5:36 pm
:applause: :twisted: :applause: :twisted: :applause: :twisted: :applause: :twisted: :applause: :twisted: :applause: :twisted:
Nicely done! The memories your family are making are priceless.
Building the TD was the best thing I ever made.
Senior Ninja
Postby john » Sat May 02, 2009 5:36 pm
Fiberglass on the edges and resin elsewhere.... painted.
Still working on the color with the wifey.
Penomeli ikibobo
john
john
Images: 261
Postby b.bodemer » Sat May 02, 2009 5:53 pm
What a start!
Profile and everything looks great................... :thumbsup: :thumbsup:
Barb
b.bodemer
Images: 315
Postby john » Sat May 02, 2009 7:40 pm
I was more in the mood for working wood. No dice...wiring had to be done first. ... that made for a frustrating day. Where is that tool? What was the plan? Not knowing what I would ultimately do with outlets, switches, and lights I just kind of wound the wires around inside the wall. Hopefully I will find the wires again once I stumble into that plan.
Today's pics.
Wiring???
Galley side of bulkhead skinned
Starting the counter
Penomeli ikibobo
john
john
Images: 261
Postby john » Sun May 03, 2009 8:40 pm
After church and after a supply run there was .....rain. After that I continued with the galley. I realized that when I ran the wires through the wall yesterday that I had neglected to run one for the tag light which I intend to mount to the hatch. Oh well. I little something to figure out later. Instead I focused on the area where the hatch meets the fixed skin. (you'll have to imagine the skin for now)
Initially I had planned to use strips of ply to get the cross section I wanted, but it occurred to me (while in church :oops: ) that my hatch was flat and would have no curve in either direction. A router with a grove bit would work just fine on a 2x4. So it was done so.
Once they were mounted I moved on to the water shedding strips at the bottom of the hatch.
pics...
Penomeli ikibobo
john
john
Images: 261
Postby MidTNJasonF » Sun May 03, 2009 9:28 pm
I very much like that profile. It looks to fit what my needs are perfectly.
What are your trailer dimensions and your planned interior finished length, width, and height?
MidTNJasonF
Postby terrybaldridge » Mon May 04, 2009 11:22 am
john wrote:Initially I had planned to use strips of ply to get the cross section I wanted, but it occurred to me (while in church :oops: ) that my hatch was flat and would have no curve in either direction. A router with a grove bit would work just fine on a 2x4. So it was done so.
Was that devine intervention?
terry
terrybaldridge
Users browsing this forum: iconicflux and 4 guests
