How do you wire it all together?
Postby Dee Bee » Fri Apr 22, 2005 7:39 am
Here is a pic of the way I wired it together...
More can be found at
http://www.nfdc.net/home/cbdb/Micro%20CamperElectric.htm
Glad to help others... comments welcome, too
DEE
Grace happens...
Dee Bee
Images: 55
Looks Good
Postby OkieSailor » Sun Apr 24, 2005 9:55 pm
Nice and neat. Did you use a heavier gauge wire for the run from the battery ground to the DC Terminal Bar (-)? Looking at the photo I could not tell if the final cable was heavier than 12ga.
The whole set up looks good.
Yes OkieSailor is an Oxymoron!!
OkieSailor
Re: Looks Good
Postby Dee Bee » Sun Apr 24, 2005 10:42 pm
OkieSailor wrote:Nice and neat. Did you use a heavier gauge wire for the run from the battery ground to the DC Terminal Bar (-)? Looking at the photo I could not tell if the final cable was heavier than 12ga.
Thanks
At present time I am using 10 gague for the mains from the battery
DEE
Grace happens...
Dee Bee
Images: 55
Users browsing this forum: Google [Bot] and 0 guests
