What about the Hinge Spar..??
Postby Larwyn » Mon Apr 25, 2005 1:34 pm
This past weekend I got all the spars glued in place to the sidewalls and ceiling. Even cut out the ceiling and framed in the Fantastic vent. But when I got to the final spar I came to a stop. I'm sure I've read about how people have beefed up the "hinge spar", but as my hinge is not expected to arrive until this Tuesday, I did not have it on hand to help in the decision making. What do you experts recommend for a hinge spar? As I used oak 1x2's for all the other spars I was thinking of doubling them up in an "L" or "T" fashion, giving both horizontal and vertical strength, but am totally open to suggestion. I'll have to wait till the hinge get's here from Grant before I know if my original plan will work. I'm building a Curved Weekender so the hatch will not be all that heavy as it does not go all the way to the floor in the back but it does get rather windy at the lakes where I usually camp... :)
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Re: What about the Hinge Spar..??
Postby DanD » Mon Apr 25, 2005 1:50 pm
Larwyn wrote: What do you experts recommend for a hinge spar?
I used oak 2 x 2 spars on the body as well as the hatch to support the hinge.
DanD
Postby toypusher » Mon Apr 25, 2005 2:37 pm
Larwyn
Just glue (Gorilla) two of the 1x2 spars together to make a 2x2 spar. If you check the grain very closely, you should be able to alternate the grain for the best strength.
Kerry
toypusher
Images: 324
Postby SteveH » Mon Apr 25, 2005 3:29 pm
Larwyn,
I'm certainly no expert, but I designed my tear for the hatch hinge to go at the top of the galley cabinet bulkhead, and doubled it with a spar. I felt the bulkhead would add lots of strength to the hinge spar.
SteveH
SteveH
Images: 42
Postby mikeschn » Mon Apr 25, 2005 3:45 pm
In my first benroy I used two of the 1x2 spars glued together... Oak at that!
In my second benroy I used two of the 1x2 spars glued together... but this time poplar, and that was plenty strong.
If I were to go it again, I would probably use poplar, but definitely glue two of the 1x2s together.
Images: 479
Postby davel » Mon Apr 25, 2005 4:27 pm
I did mine like this out of oak and it seems pretty well anchored.
I'm happy with my hinge spar but not my hatch yet.
davel
Images: 32
Postby Geron » Mon Apr 25, 2005 4:41 pm
double 1x2 oak for the henge spar is what I did. On both hatch and roof.
Geron
Geron
Images: 173
Postby Denny Unfried » Mon Apr 25, 2005 7:13 pm
Geron wrote:double 1x2 oak for the henge spar is what I did. On both hatch and roof.
Geron
Good thinking. On the original Kit trailers the hinge spar was considered the weakest part of the trailer and almost certainly the first part to fail. 2 X 3 clear oak for me.
Denny
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Postby bdosborn » Mon Apr 25, 2005 11:16 pm
DanD wrote:I used oak 2 x 2 spars on the body as well as the hatch to support the hinge.
Same here except the body spars are poplar.
Images: 516
Postby Larwyn » Tue Apr 26, 2005 7:01 am
Thanks guys, it looks like double 1x2's is the way to go for the hinge spar as I suspected.
Davel, your pic of the "L" configuration is one that I had in mind. Our walls are constructed differently but that is probably the way I will go with mine too.
Thanks again, this forum is the bestest... :)
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
hinge spars
Postby eamarquardt » Sun Nov 12, 2006 9:34 pm
I haven't built a teardrop yet but I've built lots of other things including a two ton dump trailer that uses a High-Lift mechanical jack without any problems. When I build a teardrop (materials are being ordered now) I plan on using a gear hinge that goes on top of the roof and the hatch. I'll use two pieces of 3/4 poplar for the spars and on the bottom of the spar will be a 1/8 x 1" piece of aluminum bar stock. The hinge will be through bolted through the spar and through the aluminum bar stock. The hinge will be in compression and the 1/8 bar stock will be in tension, kind of like a mini "I" beam. The stiffness will come from the aluminum, not the wood which is pretty much serving as a spacer. I'm a big believer of through bolting rather than screws when possible and I'd bet that fewer designs are stronger. The trailer will weigh a few ounces more, but everything in life is a compromise.
Eric "Gus" Marquardt
eamarquardt
Images: 150
Postby madjack » Sun Nov 12, 2006 10:05 pm
SteveH wrote:Larwyn,
...we basically did the same thing...the whole bulkhead would haveta rip out for a wood failure to occur!!!!!
Postby asianflava » Mon Nov 13, 2006 1:16 am
Me too, the hinge is on top of the bulkhead. I used poplar for my spar to make it harder for the screws to pull out. Initially I was just going to use it there but changed my mind and made all my spars out of poplar.
asianflava
Postby bledsoe3 » Mon Nov 13, 2006 8:03 am
You guys worry too much. I drove from Portland, OR to Eureka, CA with two screws holding my hatch on. I think the only time to be concerned is when the hatch is up and it's windy. I used Grant's hinge and a poplar spar. Someday maybe I'll finish it.
bledsoe3
Images: 112
Postby madjack » Mon Nov 13, 2006 10:06 am
Jim, surely you jest...no one around here worries about such things or obsesses over the frames or over builds or......
