Need help with the 7 pin connector on my Jeep
Postby dh » Fri Sep 04, 2009 11:18 pm
When I bought my Jeep it was two years old, and had a reciever hitch and a 7 pin trailer plug. The plug has Chrysler imprinted on it, and I assume it is factory.
What pin does what and how do I test to see if the vehicle has a factory break controller?
I have used a 4pin adapter and know the lights work properly, but want to make sure everything else is cool.
Is there any adjustment to a vehicle with a "Factory" brake controller? I remember back in the early 90's grandpa got his truck wired with a "new style" solid state controller that took a signel from the vehicles break light wire on the break pedal itself. I also remember lots of adjusting with brake power and delay to get them right.
dh
Postby jeep_bluetj » Fri Sep 04, 2009 11:41 pm
You most likely do NOT have a factory brake controller.
You very likely have a socket under the dash to connetct a brake controller to -- and when the vehicle was new, a pigtail was supplied to connect the brake controller.
Look in your owners manual, it'll tell you what you need and how to hook up the controller.
-- Jeff --
jeep_bluetj
Postby Shadow Catcher » Sat Sep 05, 2009 7:36 am
Try www.wkjeeps.com/wk_towing.htm
There is a good wiring diagram about half way down.
Images: 200
Postby CPlater » Sat Sep 05, 2009 8:47 am
http://www.etrailer.com/c-BC.htm has controllers and the site will help figure out what fits your vehicle. The also have some how-to videos that I found useful even though it did not cover my exact model was not covered.
Courtney
CPlater
Postby jdarkoregon » Sat Sep 05, 2009 10:36 am
To test, go buy a cheap circuit tester for 3 or 4 bucks (the kind with a clip on one end of a wire and a light/metal point on the other end) Connect the clip to the frame and put the metal point on each prong of the 7WAY and start recording what happens to each prong when you play with your lights
I found this, which should be the "standard" setup
From http://www.etrailer.com
Have fun
John
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Postby jakie » Mon Sep 07, 2009 7:26 am
My experience with 7 pin connectors is that there is usually only the 4 pins that are required to run the lights and signals. The rest you have to wire yourself, or get wired. For example, the central auxilliary power line needs to be wired from the vehicle battery, with a fuse, and possibly a device to limit how much power you draw, so you do not totally drain your TV.
I was going to build a gen benroy....now...foamie here I come
jakie
Images: 5
Postby Dale M. » Mon Sep 07, 2009 8:53 am
On late model GM trucks, everything is wired.... Brake controller, 12 volts (at 40 amps - fused under hood)....
You need to test all connections and read owners manual to see what manufacturer provided.....
Dale
Dale M.
Images: 18
Postby jakie » Mon Sep 07, 2009 9:14 am
I guess I haven't had new enough vehicles! :lol:
jakie
Images: 5
Postby Dale M. » Mon Sep 07, 2009 11:44 am
jakie wrote:I guess I haven't had new enough vehicles! :lol:
I think it varies between manufacturers.......
Best solution is to test all the connections and see what mfg actually provided..... I know with my Chevy the fuse for aux power was taped to my brake controller (accessory ) cable ... And owners manual was kind of, sorta helpful....
Dale
Dale M.
Images: 18
Postby dh » Tue Sep 08, 2009 9:54 pm
Thanks for the help.
dh
Postby wlooper89 » Thu Sep 10, 2009 11:32 pm
jdarkoregon wrote:To test, go buy a cheap circuit tester for 3 or 4 bucks (the kind with a clip on one end of a wire and a light/metal point on the other end) Connect the clip to the frame and put the metal point on each prong of the 7WAY and start recording what happens to each prong when you play with your lights
Have fun
John
My previous tow vehicle was a Jeep and the new one is also wired the same as the above diagram. It is important to note which end of the connector is referenced in the diagram. It seems a bit odd to me that it is the cable end or rear of both the male and female connectors. For examble looking at the connector on the Jeep from behind the vehicle facing the license plate, the brake wire pin is in the five o'clock position.
It will be a big plus if you have a connector under the dash for the brake controller. I did not have that on the new tow vehicle and had to run the wires to the controller from the battery, from tow vehicle brake switch to the controller and output wire to the hitch connector.
Bill
wlooper89
Images: 75
Postby Dale M. » Fri Sep 11, 2009 7:55 am
That is because that is where all the work occurs, where one does all the connecting ........ If it were other way around people would have mirror image and be total confused where to put wires.....
But then again I usually wire by the "function indicators" (numbers - letters) stamped into connector body....
Dale
Dale M.
Images: 18
