Mesh Screens for doors when set up camping
Postby SATEAR » Mon Sep 21, 2009 7:01 pm
Anyone have any ideas for installing some type of mesh screens (The kind that are on tents) to use when you are set up at the camp site and it is too warm to close the doors on your TD?
Mine will not have airconditioning or a top vent.
Thanks for the suggestions!
Gabe
SATEAR
Images: 75
Postby Ageless » Mon Sep 21, 2009 7:15 pm
Sew up a screen slightly larger than the opening and use velcro
Ageless
Postby madjack » Mon Sep 21, 2009 11:55 pm
Ageless wrote:Sew up a screen slightly larger than the opening and use velcro
yep...works quite well...you can even sew a zipper in so ya don't havvta "unvelcro" everytime you want in or out...gotta say, considering there will not be much air movement thru those screens, you really need to reconsider the top vent and since you are in the SA area, at least a Fantastic vent, if no AC is installed...if for no other reason, resale down the road...very least would be to frame in a 14.25x14.25 (with 1.5" stock) opening in the roof so the option to install a vent is available to ya..........
Postby dreadcptflint » Tue Sep 22, 2009 1:22 am
We use skeeter curtains up here. A simple curtain rod with a mesh fabric. We used fabric glue to get it to work so we didn't have to sew. They work pretty good and if we are in a real buggy place then we spritz it with mosiqetto repellant.
I have seen a few different variations out there. The folks at Camp Inn have some great looking screen doors for their teardrops. I have seen a few people make hard screens for their doors.
I hope this gives you some ideas.
Matt
dreadcptflint
Images: 19
Postby ParTaxer » Tue Sep 29, 2009 6:00 pm
The following topic under general discussion shows how I solved this problem. It worked great this past weekend! Easy and self storing.
http://tnttt.com/viewtopic.php?t=32276
I have wisdom beyond my years. In fact, I'm nearly senile.
ParTaxer
Images: 32
Postby prescobd » Tue Oct 06, 2009 6:49 pm
Camp-Inn offers screen doors for their trailers. I have them on our new 500 Ultra and am currently getting one installed on my older 500 Classic.
You may be able to make them fit your TD trailer.
http://tinycamper.com/accessories.htm
Great people to deal with.
prescobd
Postby BrwBier » Tue Oct 06, 2009 9:06 pm
Has anyone tried strips of screen like the plastic drive through door in a cold warehouse? You know, several strips of overlapping screen.
Brwbier
BrwBier
Images: 100
Postby southpennrailroad » Sun Jan 10, 2010 2:15 pm
Build another wood door just a tad smaller inside the tear door. I did this in my cargo trailer and it is great. It actually opens outward like a regular trailer camper. As long as it opens out it takes up very little room.
Long time researching the abandoned South Pennsylvania Railroad along the Pennsylvania Turnpike. God will guide me. As he has done so in the past. southpennrailroad.com
southpennrailroad
Postby bc toys » Sun Jan 10, 2010 4:44 pm
I read this a while back take to 1/2" thick boards put on weatherstripping on each one, Get your screen sew some material on each side off it about 1" wide then get a shade rod take off shade and stapple on your screen and put it behind the weather stripping and pull down and roll up when you need it up and you can sew a zipper in the middle
bc toys
Images: 42
Postby southpennrailroad » Sun Jan 10, 2010 4:47 pm
The screens are removable from the wooden door. I work for a window company.
southpennrailroad
Postby Kayperkay » Sun Jan 17, 2010 11:02 pm
Here's mine....made of canvas type fabric with screen sewn in the middle....Velcro's at the top and tucks right in at the door by the mattress.
LUV IT.....!!! 8)
Kay
Director Jefferson State Tearjerkers
Life is Devine Chaos....Embrace it...Forgive yourself......Breathe.....And enjoy the Ride...!!
Image Image Image
Kayperkay
Images: 66
Postby Nitroxjunkie71 » Mon Feb 01, 2010 6:40 pm
Screen's are the best... :thumbsup:
Jeff
Image Image Image
Nitroxjunkie71
cargotrlrman
Images: 232
Location: Originally from Battle Creek Michigan, I now reside in Indianapolis Indiana
Postby nevadatear » Thu Feb 18, 2010 12:40 am
I did the overlapping pieces of screen thing that is velcro around the edges of the molding on the door. that way I don't have to unvelcro every time, but don't have to unzip either.
Owner,Desert Metal Products. Custom machine shop. Inventory of thousands of bearings and seals, from the common to the archaic.
nevadatear
Images: 145
Postby NWsage » Fri Feb 19, 2010 1:32 am
nevadatear wrote:I did the overlapping pieces of screen thing that is velcro around the edges of the molding on the door. that way I don't have to unvelcro every time, but don't have to unzip either.
That sounds like a very clever idea. :applause:
Do you have any pictures of the details that you can share?
Thanks, Suanne
NWsage
Images: 6
Postby doris s. » Fri Feb 19, 2010 4:38 pm
Kayperkay,
I was going to make my screen a full door screen but I love your idea of having canvas on the bottom for a little privacy. Thanks for the idea!
Doris
doris s.
Images: 32
Return to Camping Secrets
