Two good scores today in the electrical dept.
Postby Marck » Wed May 18, 2005 9:58 pm
I lucked into one good find and made a purchase as well.
First, my neighbor who knows about what I am building asked me if I could use this:
http://img.photobucket.com/albums/v111/ ... rbox-1.jpg
a square D breaker box with 2 15 amp breakers installed for free... heck yes I can use it.
Then I had to make a stop at A&A auto for some other items, and came across this:
http://img.photobucket.com/albums/v111/ ... itch-1.jpg
http://img.photobucket.com/albums/v111/ ... itch-2.jpg
I didn't want a "Frankenstein" type blade switch, and when I stumbled across this I thought it was perfect what with my kids etc....
It's a battery cutoff switch that uses a plastic key to turn it on-off.
$9.99 plus tax.... not too bad.
I can install it right in my panel, and not have to go to the battery (which will be tucked away) to kill the power.
You want to build WHAT?????
40 isn't middle aged....
IT'S YOUTH PART II
Marck
Images: 64
Postby metoady » Fri May 20, 2005 7:38 pm
we use the same type of battery cut out on out race cars
just safty wire or chain the little handle or they get lost easly
,akes for a cheep and safe way to shut of power :applause:
Some days it not even worth chewing
through the restraints.......
http://www.mikenchell.com/forums/album_ ... ser_id=838
metoady
Images: 26
Postby bigmcgiv » Sat May 21, 2005 10:27 pm
:? you should have stop by and see me a cee-kay atuo in wilkes-barre i manage it . also i was wondering if i can see your tear. tks matt :thumbsup:
bigmcgiv
Postby Marck » Sun May 22, 2005 7:44 am
Mat,
I'm up in Harding... the tear isn't ready to go down the road yet, but soon.
I will be down in W-B this week.... I'll stop in.
IT'S YOUTH PART II
Marck
Images: 64
Postby fornesto » Mon May 23, 2005 4:04 pm
I used that exact same switch and mounted it into the face of a black project box from Radio Shack that contains my fuse blocks and ground bars (isolated and taped of course). Turning off my power is as easy as turning the key. I also hung the key on a string so it could never be lost.
fornesto
Users browsing this forum: Bing [Bot] and 20 guests
