I'm starting to attach my aluminum trim. I'm putting on a healthy bead of silicone caulk under the trim and screwing it down. What did you guys do to clean off the excess silicone? Did you let it dry and then clean off the excess, or did you clean it off when it was wet?
I applied one piece of trim so far. I let the caulk dry then I tried to remove the excess by cutting along the trim with a razor knife and peeling the excess silicone off. This did not work that great. A fair amount of silicone "residue" still remains.
Any suggestions for easy clean up????
