I finally wired up my electrical system yesterday.
I have more photos on my web site (the wireing photos start at slide 27).
SteveH wrote:Tom,
Your wiring looks very nice. Some questions...where'd you get the battery, and what did you have to pay?
Thanks,
Loader wrote:I know this is an old post, however, when looking at yor battery install, is that the earth ground (ground block to trailer frame) I see going through the floor at the bottom front right corner of the battery? What did you seal it with? Silicone?
I am doing a very similar install...... ok, I copied yours! !
Loader wrote:Tom, did do a great job on his set up. What do they say, imitation is the greatest flattery.
PaulC wrote:Earl, They call it a floating circuit when it is not earthed to your frame. Provided everything is fused and earthed directly to the battery you basically have a torch type circuit. No problems with doing it this way and eases the problem of crossed circuits with the vehicle if you have a short in either.
Cheers
Paul
I copied Tom's idea, just need to add the inverter and order my deltran unit. Otherwise, all wired up. Loader
