Fender mounting
Fender mounting
Postby rooster » Wed Sep 21, 2005 10:54 am
My buddy was asking how are the fenders were mounted. Were hoping to mount my fenders this weekend. I look at all the pictures on this forum but can't really see how differant ones attached thier fenders. :thinking:
Can someone give a a clue.
Beware of what she wishes....especially with that twinkle in her eye and that mischievious smile....you know it's gonna cost....
rooster
Images: 42
Postby TRAIL-OF-TEARS » Wed Sep 21, 2005 11:19 am
I just drilled holes in the fender and screwed it to the side using #10 3/4" hex head screws. It works for me.
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
Postby SteveH » Wed Sep 21, 2005 1:31 pm
I went a little further, used 1/4 X 1 1/2" elevator bolts at the top thru the wood, and 1/4" bolts thru the frame at the bottom.
SteveH
SteveH
Images: 42
Postby Denny Unfried » Wed Sep 21, 2005 2:16 pm
I threaded inserts into the plywood 1/8" shy of going through. Then the fenders are attached using 1/4-20" cap screws & fender washers. This leaves it clean and smooth on the inside. Of course this works only if you are building a solid sided tear.
Denny
Ghost image showing fender in place.
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Fender mounting
Postby rooster » Wed Sep 21, 2005 5:41 pm
Three different ideas, eneany, meany, miney moe....
SteveJ, I'm a retired machinest and #10 screws seems a little light, not that they won't work, I just sort-a over build. Like the Titanic.
SteveH, 1/4-20 seems a little along my style, going with stainless steel and castlelated nuts. What are elevator bolts anyway, never heard of them?
Now, Dennys idea was rather cool, but I don't want to do that much work.
I hope I don't come accross that I'm lazy, just tired a little.
Did any of you use fender felts?
Thanks for the ideas.
Jim, :applause:
rooster
Images: 42
Postby SteveH » Wed Sep 21, 2005 6:10 pm
Jim,
An elevator bolt is like a carriage bolt, only better. It has a bigger head that is flat. If a 1/4" carriage bolt has a head that is about 5/8" in diameter, an elevator bolt's head would be about an inch in diameter. I used them to bolt the floor to the frame also, only 3/8" size.
SteveH
SteveH
Images: 42
Postby ALAN GEDDES » Wed Sep 21, 2005 7:31 pm
Don't forget to put a little RTV or something to prevent any wood damage. A lot of water gets thrown up inside those fenders.
Alan
ALAN GEDDES
Images: 34
Postby SteveH » Wed Sep 21, 2005 7:49 pm
Allen,
You are right about that. I sealed up all the fender bolts with silicone and also installed fender welting between the fenders and trailer. Should keep it dry.
SteveH
SteveH
Images: 42
Postby Steve Frederick » Wed Sep 21, 2005 9:25 pm
I used threaded inserts like Denny, Actually I stole the idea from him!! :o
I added blocking to the walls where I planned to mount the fenders. (The walls are an insulated sandwich) I used 1/4"-20 stainless bolts, fender washers with a dab of marine RTV.
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby norm perkiss » Wed Sep 21, 2005 9:29 pm
I used T-nuts. Drilled and set them in the 1/2" ply before closing up the inside and putting on outside skin. I used SS hex bolts and caulking with vinyl fender beading. Seems to be working perfectly.
norm perkiss
Images: 62
Fender mounting
Postby rooster » Wed Sep 21, 2005 9:41 pm
Thanks guys for the info. Now I have to locate elevator bolts tomorrow and hope they don't look at me funny. My riend is installing my shocks for me, what a buddy. Larry Sorensen added shocks to his tear after he used it awhile. Some of the hwys. up here aren't the greatest after a winter of frost heaves push up the hwy. in places.
Later, Jim
rooster
Images: 42
Postby Roly Nelson » Wed Sep 21, 2005 10:11 pm
Just to go off on another tangent, I made my fenders out of 1/8" plywood and 3/4" pine. I cut a curved groove into the side of my tear, and a matching groove into the outside fender section. Then glued, clamped them together and installed about 50 glue-blocks ;on the underside, to add strength. The whole mess is coated with Line-X bed-liner and even though it is a bit different, seems to be working out fairly well. (it evens passes the jump-on-the-fender test)
The new 6 footer has HF standard fenders, screwed tightly to solid wood framing in the tear floor. I guess when the screws rust off, the fenders will fall off. Oh well, as I say if it's wood, it' good. (does that mean if it isn't wood, it isn't good?) Naw, just different.
Roly, finally turning my goofy ideas into reality.
Roly Nelson
L'il Ol' Woody Builder
Postby asianflava » Thu Sep 22, 2005 1:29 am
Man, looking at your setups makes me think that I need to beef mine up. I used 3/8 in bolts thru the solid portion of the wall and 3/8in bolts with T-nuts on the hollow parts. All use (approiately enough) fender washers. I only have 4 bolts per fender. Maybe I'll add 2 more bolts on each side. I didn't want too many because the T-nuts show on the interior, I figure I could live with 2 showing.
asianflava
Postby SteveH » Thu Sep 22, 2005 6:42 am
Rocky,
I've only got 4 each 1/4" bolts per fender in mine and it's got about 8,000 miles on it already with no problems so far.
SteveH
SteveH
Images: 42
Postby TRAIL-OF-TEARS » Thu Sep 22, 2005 10:19 am
I had first used just some #10 5/8" self tappers but after about 6,000 miles the drivers side fender started to loosen up so I replaced the self tappers with the metal screws. got about 7 screw each side. They seem to be very solid.
Steve J.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
