Color your fire
Color your fire
Postby cubby_1969 » Tue Oct 11, 2005 3:27 pm
Take 3/4" copper tubing cut to about 6" long. Drill random holes all over it. I use 1/4" holes and it works well. Slide a piece of garden hose inside and throw it in the fire. You'll get cool blues and greens. When it's done, use a stick to pull out the pipe and stick another peice of hose in. You'll get about 10 uses before the pipe gets too soft and goes flat.
Duane
PS - don't cook over it. CAN'T BE GOOD FOR YOU!! :?
Lancaster, PA
cubby_1969
Images: 7
Postby Laredo » Sat Oct 15, 2005 10:11 pm
when i was a kid we lived on a farm in the ozarks.
my dad poured a concrete slab 8'x10' around the top of the well we had drilled, and afterward burned the concrete sacks in the barrel on top of the trash. the fire was grass-green.
Laredo
Postby BrianB » Sun Nov 13, 2005 6:31 am
I had an old camp counselor who was a chemistry major and every year he'd bring out a big tool box filled with jars of sawdust that he let soak in various types of chemicals. He could turn the fire yellow, orange, blue, green, white. Of course we're all brain damaged now, but it was a lot of fun.
BrianB
Postby asianflava » Sun Nov 13, 2005 3:32 pm
Mike should know how to color fire. People color the flame on their homebrew rocket engines. He should have his level 2 cert by now.
asianflava
Postby Hardin Valley Magic » Wed Nov 30, 2005 9:59 pm
Copper tubing in a fire.. We used to burn copper wire to get the insulation off so we could sell as #1 copper.higher price paid. Yes the smoke and fire was colorful but,the smoke would give you one heck of a head ache!! And now if the e.p.a. catches us, so rumor has it, well it supposed to be one heck of a fine.. $> $>
aka Steven D.
Hardin Valley Magic
Postby Nytewyng » Wed May 03, 2006 9:30 pm
A real simple solution for camp fire colors http://www.duraflame.com/prod_firelog01.html
Rob and Deb Mangano
Nytewyng
Images: 30
Postby sdtripper2 » Wed May 03, 2006 11:12 pm
Rob and Deb:
I too like the DuraFlame logs.
They are easy to light and cam be put on top of the grill at a park to give off heat and color and they burn a long time without a mess. For a quiet eve put as many logs at once as you want fire 1,2, or 3 and have a peaceful time.
sdtripper2
Search Garoux
Images: 168
Return to Camping Secrets
