JohnF wrote:My problem seems to be finding a mounting location so that the hatch can fold down without the arm jamming against the ledge of the cabinetry.
TonyCooper wrote:I think another possible idea is to have an elbow extension similar to the one pictured above that has a small gas strut centered on the joint to push the elbow open and hold the hatch up. You would not want the joint to fully extend as getting it to close would then be a problem.
Someone would need to work out the geometry, but I think this idea has merit and at first blush seems to use smaller hardware and possibly less space. There would be three points of connection to the teardrop. The side wall for the elbow bracket, the hatch connection of the elbow bracket, and the sidewall connection for the small gas strut.
Disclaimer: I have not given this a great deal of thought... it popped into my head when I saw Kevin A's setup.
angib wrote:It would seem a good idea with all hatches to fit or trial-fit the hatch supports (of any type) before the hatch skin is put on, so that their operation can be seen as the hatch goes down.
Andrew
JohnF wrote:SOS ! Mayday ! Help !!
I hesitate to drill the mounts off and try to put them back on in reverse, or perhaps even bend them radically for best fit..
doug hodder wrote:John....I had a similar situation with my tear....only trying to use the gas shocks....no clearance....got 2 mohogany sticks now....I think you may find that by the time you find a place that they will work in, you may not have the height you want on the hatch....just what I found....gas shocks may also have the same problem in your application...maybe a good thing for new builders to think of before hand...although I think a lot of us don't realize that issue until we're in the thick of it....it sounds like a number of us have run into the same problem....Denny seems to be thinking ahead however....Doug
angib wrote:Kevin,
Those lock-up struts are simple and great for series production, but they have some practical difficulties for the one-off builder. The two mounting points come close together when the hatch is down and that makes them very sensitive to their position. Move one mount 1/4" nearer or further away from the hatch hinge and the knuckle (where the spring is) moves up or down by many times as much - and possibly out through the hatch skin!
A very similar problem afflicts the folding door on the Wild Goose trailer - on the geometry in the original plans, the folded door goes through the floor!
Andrew
