Postby Bandit » Wed Feb 08, 2006 8:28 pm
Has anyone tried Cold Cathode Fluorescents?
Supposedly these are 12V low voltage, long life lights.
I saw some nice reading lights in, I believe, Tom's TD. Where did you find these and do they offer other options?
First Metal Cut 02/11/06
Complete! (Almost) 08/22/06
Looking for a trip in the SPRING!!!!
Not Up to Testing the Heater!!!
Thanks for all the HELP!!!!
Postby Chuck Craven » Wed Feb 08, 2006 9:16 pm
Cold Cathode Fluorescents:
They use high voltage across the tube like a Neon tube works.
They chop the 12v in to a high frequency ac voltage and feed it to a
transformer. The secondary of the transformer is feed to the florescent tube. There light output is a little less than a normal fluorescent light and the power to Run them is also a little less. The only drawback is that they radiate RF noise that can interfere with radio, TV and other RF equipment like your car door clicker. The compact fluorescent lights work on the same principle except for 110 vac and they also put out RF interference. They take the 110 v ac and chop it up to a higher frequency to keep the transformers small so it can be mounted in the base of the bulb.
Chuck a new td builder
Chuck Craven
Images: 62
