Air Conditioner pics
Postby 48Rob » Sun Feb 12, 2006 7:58 am
Rob,
Do you by chance a photo of AC from the inside? Didn't see it in your album.
Thanks
_________________
Earl
"Loader"
Earl,
Here are some quick pics.
Rob
This shows the unit in the bottom cabinet.
The exterior door is closed.
When opened, the a/c slides out/back, about 6".
48Rob
Postby Sonetpro » Sun Feb 12, 2006 8:15 am
Good Job :applause:
Sonetpro
Images: 107
Postby Loader » Sun Feb 12, 2006 8:20 am
Thanks Rob. That is a great install. Doesn't take valuable space from the cabin, looks good from both inside and out.
Thanks for sharing. :thumbsup:
Earl & Kerry
"Loader"
Loader
Images: 245
Postby 48Rob » Sun Feb 12, 2006 10:59 am
You're welcome!
I should have mentioned, I installed aluminum angle on the sides and top of the unit so it won't "fall out".
It also gave me a place to install some open cell foam weatherstrip to seal the opening when its running.
Rob
48Rob
Postby cracker39 » Sun Feb 12, 2006 1:06 pm
Rob, how is that Haier AC unit? I'm thinking of getting one. Either that or the Goldstar, as both have the upward directed air flow. The Haier states that it is "Ultra Quiet". Is that true?
Dale
cracker39
Images: 233
Postby GeorgeT » Sun Feb 12, 2006 2:08 pm
Another possibility would be to make the door open from the top to create a shade and protection for the protruding AC unit. The AC unit also holds the door open. Mine is one of those Home Depot elcheapo units. It does a great job.
Inside the when the AC is not extended it sits on a couple of wooden rails. Here you see the unit extended.
and with the AC in traveling position
Lookin' up in da skize with ize on da prize
http://home.earthlink.net/~g.teague/
GeorgeT
Postby 48Rob » Sun Feb 12, 2006 5:27 pm
Dale,
It is far more quiet than most of the small units I've had, but not "ultra quiet".
Still, the best I could find for the money.
Georges setup with the door hinged on top is a better design.
I didn't have room on this one :cry:
Rob
48Rob
Postby cracker39 » Sun Feb 12, 2006 8:03 pm
Rob, that sounds good enough for me. Haier it is. If it's fairly quiet, and blows the air upward, that's what I need.
Dale
cracker39
Images: 233
Postby UTDRob » Sun Feb 12, 2006 8:28 pm
I love these AC ideas. I saw George's a few weeks ago when I began perusing the hall of fame for ideas. I am definitely setting mine up like that. I have the $80 Home Depot AC (something I already have and don't have to buy, I like that) already waiting for its flap.
UTDRob
Images: 19
