Galley vents
Galley vents
Postby seahorse » Tue Feb 28, 2006 10:43 pm
I see many teardrops, with 2 small round aluminum vents on either side of galley......Where can they be purchased?
seahorse
Images: 39
Postby Nitetimes » Tue Feb 28, 2006 10:58 pm
Are you refering to these ones? Vents
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Round Vents Galley
Postby sdtripper2 » Tue Feb 28, 2006 11:10 pm
Here is one source forRound Vents: for the Galley area on either side.
There are most likely many more vendors but is this the type your looking for>?
Here are two more web sites for round vents .
Another round vent
One more round vent
sdtripper2
Search Garoux
Images: 168
Postby Gage » Wed Mar 01, 2006 1:22 am
Am I missing something? Why would you want vents on the side of your galley. I've seen a lot of teardrops in my time but have never seen vents for the galley. Maybe I'm just not looking for them. Come April I'm going to be at a gathering where there is going to be 100+ teardrops. Now I know what I'm going to be doing. :moom walk:
Have a good day.
8)
Image Image Image
Gage
Images: 28
Postby madjack » Wed Mar 01, 2006 1:44 am
seahorsie, I think this may be what you are looking for(maybe)
http://www.defender.com/product.jsp?pat ... 9&id=46663
Camp_Inn uses something similar to relieve backpressure in the cabin when shutting doors and we are going to use a couple for battery box vent covers
Vents Round
Postby sdtripper2 » Wed Mar 01, 2006 1:52 am
Gage:
The Hunter Shadow Teardrop Trailer has the round air vents on either side of the top rear of the galley.
Here are some examples:
5x10 Hunter fat Shadow Teardrop
Hunter Shadow main web site
sdtripper2
Search Garoux
Images: 168
Postby dacrazyrn » Wed Mar 01, 2006 2:53 am
Those minirature louvered aluminum vents can be had at HD or Lowe's for less than a buck. Also square ones. They are located in the roofing areas for usually around a buck.
I plan on at least one for a battery vent-slash-water tank vent.
dacrazyrn
Images: 74
Postby seahorse » Wed Mar 01, 2006 7:09 am
Gage wrote:Am I missing something? Why would you want vents on the side of your galley. I've seen a lot of teardrops in my time but have never seen vents for the galley. Maybe I'm just not looking for them. Come April I'm going to be at a gathering where there is going to be 100+ teardrops. Now I know what I'm going to be doing. :moom walk:
Have a good day.
8)
Thanks everyone, just what I was looking for :D .............. Gage, If the galley is closed up on a hot day, wouldn't heat build up???
seahorse
Images: 39
Postby David Niver » Wed Mar 01, 2006 7:27 am
I picked up mine from a rv dealer for a couple of bucks each.
I use them so I can run the exhaust fan for the cabin with the hatch closed.
David Niver
David Niver
Postby seahorse » Wed Mar 01, 2006 7:38 am
David Niver wrote:I picked up mine from a rv dealer for a couple of bucks each.
David Niver
David, another reason to install vents............thanks, Rob
seahorse
Images: 39
Postby Mitheral » Wed Mar 01, 2006 10:57 am
dacrazyrn wrote:Those minirature louvered aluminum vents can be had at HD or Lowe's for less than a buck. Also square ones. They are located in the roofing areas for usually around a buck.
Aluminum is a poor choice for a battery compartment vent, the fumes will eat it away quickly. Stainless or plastic is a better choice.
Mitheral
Images: 19
Postby Gage » Wed Mar 01, 2006 3:59 pm
seahorse wrote: <snip> Thanks everyone, just what I was looking for :D .............. Gage, If the galley is closed up on a hot day, wouldn't heat build up???
No more than the inside of my tear. I have insulation also in my hatch for those hot days. Now don't get me wrong. When I built mine, I just didn't hear of venting the galley so didn't give it much thought.
Have a good day.
8)
Image Image Image
Gage
Images: 28
Postby seahorse » Wed Mar 01, 2006 6:56 pm
Have a good day.
8)
Might be any easy addition to that SWEET teardrop of yours :thumbsup:
seahorse
Images: 39
Postby IndyTom » Wed Mar 01, 2006 10:19 pm
The Kuffle Creek website on installing a/c in a tear suggests using them along with a pair of vents between the sleeping compartment and the galley. The also recomend single pass a/c. The vents serve to vent inside air into the galley and the outter ones then vent the air to the outside. They say this cools the galley and perhaps extends the life of you ice, if you have a cooler in the galley. Of course, the hatch has to be closed for this to work.
http://www.kuffelcreek.com/teardrop_a_c.htm
Never trust a skinny cook
IndyTom
Images: 42
Postby Gerdo » Wed Mar 01, 2006 10:53 pm
I put vent/drains in the front corners of the floor of my galley. I didn't want propane to buildup and if my cooler ice/water should splash out it can drain. I used a couple of 2" PVC elbows that are sealed to holes through the floor, facing backwards, and sink drain screens screwed down.
Gerdo
Images: 156
