Marking the notch
Marking the notch
Postby asianflava » Tue Mar 14, 2006 6:25 am
I had a genius idea; I needed to mark the notch for the hatch weather stripping. I tried to use a square but it wasn’t accurate enough because it rocked back and forth while striking the scribe. I figured that 2 points would be best so that it wouldn’t rock yet still follow the arc.
I took a U-bolt and notched it in 2 places, then I tie wrapped it to a compass. The 2 legs of the u-bolt followed the arc while the pencil marked the amount of sidewall I needed to remove. This was all done using the hatch as the reference.
Click thumbnails for larger pic.
Modding the compass:
The mark:
asianflava
Postby Rickxr2 » Tue Mar 14, 2006 7:38 am
:applause: Nice idea! I've had several times a three legged compass would come in handy. :thumbsup:
Image Image Image
Rickxr2
Images: 125
Postby 40deluxecoupe » Tue Mar 14, 2006 7:59 am
So how will you cut to the line? This is my next step, wondering what is the best way.
40deluxecoupe
Images: 14
Postby asianflava » Tue Mar 14, 2006 5:20 pm
I've still gotta figure that one out. I have a couple different options: sand down to the line with a belt sander, jigsaw, router.
What I'm considering is a hybrid of the three I can cut down with the jigsaw, square up the edge with a router, then hit it lightly with the sander to clean it up.
asianflava
Postby Chris C » Tue Mar 14, 2006 5:59 pm
Just a suggestion:
Put a rabbeting bit in a router and make a pass on the surface you want to "cut back". Use a bit that matches the step you want. Then take a flush cut router bit and run the bearing on the surface you just cut. Of course, the router will have to be used from the opposite side from the first cut. This cut will bring the surface down to the new level. Try it on a sample piece........it works.
Chris :D
Chris C
Postby goldcoop » Tue Mar 14, 2006 6:28 pm
Rickxr2 wrote::applause: Nice idea! I've had several times a three legged compass would come in handy. :thumbsup:
http://www.leevalley.com/wood/page.aspx ... 50298&ap=1
Coop
goldcoop
Images: 32
Postby Sonetpro » Tue Mar 14, 2006 6:37 pm
Chris C wrote:Just a suggestion:
That's how I did mine. Worked perfect.
Sonetpro
Images: 107
Postby asianflava » Tue Mar 14, 2006 11:28 pm
Coop
I actually saw that one in the catalog. Then I saw the price! :shock:
asianflava
Postby asianflava » Tue Mar 14, 2006 11:33 pm
This is what I ended up doing. Of course I didn't read Chris' suggestion till after I was done.
Anyway, on the areas where there was a lot of material to remove, I cut it down closer to the line with the jigsaw, the rest was taken down with the belt sander. I put a slight taper in it so that I could sand down to the line quicker. When I sanded it down to the line, I used a top bearing straight bit to square up the edge. I hit it with the sander one more time to clean up things some more when I was done with the router.
asianflava
Postby doug hodder » Tue Mar 14, 2006 11:36 pm
Asian....just make sure you seal up the raw plywood edge well...water penetration may make it delam....Doug
Postby Guest » Tue Mar 14, 2006 11:38 pm
Good idea Rocky! :thumbsup:
BTW- I really like your clickable thumbs... Took a peek at the text. ;)
Guest
Postby asianflava » Wed Mar 15, 2006 12:04 am
doug hodder wrote:Asian....just make sure you seal up the raw plywood edge well...water penetration may make it delam....Doug
Yup, I had put some epoxy on the edge to seal it. I ended up sanding and cutting it off to make the notch.
I'll mix some more up and put it on the new edge. I also have to roll some on the rear roll pan because I forgot to put some on when I did the rest of the trailer.
My goals for the week are to get it water tight so I can camp this weekend. Took the whole week off to work on the trailer. Well, actually 2 days because I had to take Fri and Sat to camp.
asianflava
