Pressure regulator for 1# LP bottle?
Postby mikeschn » Fri Mar 17, 2006 11:18 am
Hey guys,
I just discovered that I can't run 1# propane bottles on my stove, because my stove requires a pressure regulator between the bottle and the stove. So do they make a pressure regulator to fit a 1# bottle? Or is there a fix that I need to do to the stove. If anyone needs to see pictures of the stove, just say so...
Images: 479
Postby rainjer » Fri Mar 17, 2006 11:47 am
A picture would help. Make sure you include pics of the fittings.
rainjer
King Koleman
Images: 11
Postby mikeschn » Fri Mar 17, 2006 12:16 pm
Okay, here's the pictures of the stove...
Images: 479
Postby raru » Fri Mar 17, 2006 1:08 pm
is this for an emergency case where you would disconnect from your bulk tank? does that unit have a regulator that you can install the 1lb bottle connection upstream of? regardless, i would think you could go to a plumbing supply and get a suitable NG regulator for your needs. you just need to know what pressure the stove needs from it's literature and to make sure that you get adequate gas flow. some merely restrict gas flow to bring down the pressure whereas others are more full flow type units.
Raul
raru
Postby mikeschn » Fri Mar 17, 2006 2:07 pm
Raul,
That's exactly right... My hose has a pressure regulator on one end that fits onto my bulk tank. If I run out, and have no way to refill the bulk tank, I'd like to be able to use a 1# bottle...
The pressure regulator is part of the hose assembly (assy for Angib), and can not be screwed onto a 1# bottle... Let me get some hose pictures...
Images: 479
Postby mikeschn » Fri Mar 17, 2006 2:22 pm
Raul,
This arrangement, hooked up to a 1# bottle doesn't work, due to the absence of the pressure regulator.
This arrangement works just fine...
Here's a close up of the ends that connect to the tank/bottle
Images: 479
Postby SteveH » Fri Mar 17, 2006 2:32 pm
Mike,
The adapter that is available for filling one pound containers from bulk tanks, can also be used to put the fuel from a one pound container into the bulk tank. If you had one of those adapters, you could carry it and a one pound container to put fuel into your bulk tank in an emergency. ;)
SteveH
SteveH
Images: 42
Postby raru » Fri Mar 17, 2006 4:24 pm
looks like you can't just put in a regular regulator, you'll need something approved by the RVIA for RV's and travel trailers. Either way, there seemed to be several options available...
http://www.rvpartscenter.com/prodselect ... 37&CID=216
Just make sure that the location of the regulator is properly vented or run a vent line outside.
Raul
raru
Postby len19070 » Fri Mar 17, 2006 5:21 pm
Mike ya need something like this;
http://www.campingworld.com/browse/skus ... unum=24028
Its an emergency adapter incase your big bottle kicks you can run off of a 1lb'er. I use one on mine. I used to run a 5lb bottle with a 1lb bottle as a back up. But after the 5lb'er kicked and I went to a 1lb'er as a back up and I stayed with the 1lb'er. It connects from the 1lb bottle to the regulator.
Happy Trails
Len
len19070
Images: 24
Postby mikeschn » Fri Mar 17, 2006 5:29 pm
That's perfect! Thanks Len...
Images: 479
Postby len19070 » Sat Mar 18, 2006 4:57 am
Mike the one I showed you from Camping World, the "Propane Grill Steak Saver Adapter" is by Mr. Heater.
Marshall Brass also makes one called
"Second Chance Grill Adapter" part # G-480
Happy Trails
Len
len19070
Images: 24
Postby Ken A Hood » Sat Mar 18, 2006 11:42 am
Just browsing, and came accross this.........Not sure if it's what your looking for though.
http://members.shaw.ca/DL0006/flyer_english.pdf
It's on page 33, on the right hand side... Item #6050032
Ken A Hood
Images: 42
Postby Cliffmeister2000 » Sun Feb 08, 2009 4:53 pm
Reviving an older thread, Northern Tool has one of these for $21.99
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200306161_200306161
They look pretty darned handy to me. Never needed one camping, but certainly have needed one around the back yard BBQ grill!
And here's an adaptor that will let you fill up those empty 1 lb canisters!
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_11829_11829
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby 48Rob » Sun Feb 08, 2009 5:22 pm
Mike,
On a former tear, I used a regulator from a BBQ. grill, mounted under the countertop.
You can just see it in the picture behind the brass shelf support.
I used only a 1# bottle with that setup, no other tanks.
The system started with the bottle, then the shutoff, the regulator, and finally the stove.
Took very little space.
<img src="http://w48rob.wik.is/@api/deki/files/347/=m.jpg">
On my latest, I have an 11# bottle, with fittings to allow use of a 1# bottle, or the 11# bottle.
<img src="http://img.photobucket.com/albums/v284/1948rob/Cabin%20car%20project/tank2.jpg?t=1234131563">
<img src="http://img.photobucket.com/albums/v284/1948rob/Cabin%20car%20project/tank1.jpg?t=1234131507">
Rob
Visit Rob's World Web Page!
48Rob
Postby Cliffmeister2000 » Sun Feb 08, 2009 6:06 pm
48Rob wrote:Mike,
Rob
That's pretty neat, Rob! :applause: What is the purpose of the tube that goes down between the 1# and the 11#? Looks like the opposite of an air chamber in houshold plumbing (because it points down instead of up).
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
