Homemade Power Source and Battery Charger
Postby Dee Bee » Fri Apr 21, 2006 12:22 pm
Has any electrical wizzard made one of these? It facinates me to learn that there are ways to do it yourself. I'd like to try my hand at making one.
Info is found at http://theepicenter.com/tow02077.html
Also http://www.theepicenter.com//tow082099.html
Dee Bee
Grace happens...
Dee Bee
Images: 55
Postby Chuck Craven » Fri Apr 21, 2006 6:50 pm
Yep!
:lol: Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby Spadinator » Fri Apr 21, 2006 9:19 pm
Yep...made mine out of a VW generator and a 2 horse Briggs engine. Mine works perfectly!!!!!! :D
Never do anything you don't want to explain to the paramedics.
Spadinator
Images: 47
Postby EZ » Fri Apr 21, 2006 9:25 pm
That is cool! Does it really take 3 1/2 horsepower to spin an alternator? Maybe they just use those because they are cheap and plentiful.
Ed
EZ
Images: 54
Postby Chuck Craven » Fri Apr 21, 2006 9:36 pm
I used a 3-horse vertical shaft lawn moor motor and a ford 1970’s generator with regulator. Got 30 amps out of it. The second was the same motor but used a jeep alternator and regulator got 30 amps out of it too. Then I took a GM alternator and took the windings apart and rewired it for 120v ac. Worked good for universal tools like skill saw and drills but the frequency was to high for anything with a transformer in it. Got 120v +/- 20v at 12 amps out of it. I think if I used a bigger motor it could have got a little more amp’s. 8)
Chuck
Chuck Craven
Images: 62
Postby Q » Sat Apr 22, 2006 4:50 am
I've built several. Since my house is solar PV powered I occationally need to charge the battery bank after several days of cloudy weather. My biggest one uses a 16.5 hp OHV Briggs lawn tractor engine coupled to a 125 amp alternator. The one I use more frequently is a 5 hp OHC Honda engine coupled to a 65 amp Ford alternator. I have large quiet mufflers on both.
BTW I use a piece of nichrome wire from a dryer heating element as a field resistor.
Q
Q
Postby Dee Bee » Sat Apr 22, 2006 7:36 am
Ok You know the Forum plea... pictures please!
Dee
Grace happens...
Dee Bee
Images: 55
Postby Gadget Man » Sun May 14, 2006 12:13 pm
Wow, Why didn't I think of that...
I once made an air compressor out of an Air conditioner compressor out of an old Caddilac and an electric motor out of a washing machine.
But I have the same question as EZ, do you realy need a 3 hp motor?
I wonder if something as small as a Gas weed trimmer engine would work?
How long does this have to run to recharge a battery? Hours? Days?
EZ, I like the progrees you are making on your rig, especialy the 60's version. wink-wink...
But one question...? How do you shovel the snow out of that driveway of yours??? ha ha ha , (you have to be a true Minnesotant to appreciate a qustion like that) Keep up the good work.
Mr. Gadget
My kids may be smarter than me,
But I know more.
Gadget Man
Images: 23
Postby rampage » Sun May 14, 2006 3:26 pm
I have a good gas running weed eater that the shaft broke on. Could I build one of these? ...or any other ideas what I could do with the motor. I saw a blender for a boat that looked like a weed eater motor on the bottom. I was thinking about picking up a blender from a thrift store and seeing what I could do.
Hey Chip, How about some pickle slushy's :picklejuice:
"If you can't be a good example, then you'll just have to be a horrible warning"
rampage
Images: 5
Postby SteveH » Sun May 14, 2006 3:57 pm
Assuming the average alternator puts out 60 amps...that's equal to 720 watts (60 X 12 = 720) So then 720 is equal to .9648 HP (720 X .00134) Most weed eater motors should be about 2 HP or more. I have a gas helicopter motor that is .23 CC, a little smaller than the weedeater motors, and it is rated at 3 HP. So, in short, the weedeater motor would work fine, but maybe a little loud.
SteveH
SteveH
Images: 42
Postby Chris C » Sun May 14, 2006 4:05 pm
The biggest problem with homemade generators is controlling the output. I used to have quite a bit of literature on the subject, but one thing which stuck in my mind was how often there were warnings about destroying the batteries by overcharging. If I can find a link, I'll share it.
Also, here is a link to a previous discussion on the subject here on the site: http://tnttt.com/viewto ... 21&start=0
Chris :D
Chris C
Postby Larwyn » Sun May 14, 2006 4:37 pm
rampage wrote:I have a good gas running weed eater that the shaft broke on.
Would that make it a "weed tease"......????
All bark and no bite........... :lol:
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby GeorgeTelford » Sun May 14, 2006 4:45 pm
Hi Chris
Its an alternator, which will have a standard regulator, ergo overcharging not a problem (alternator cannot even properly charge a battery)
Add a smart reg and these would be excelent chargers
weed whacker motor will not "cut it" with an alternator for several reasons RPM being one and power being the other, for a small alternator the power required from Stall is just to great.
GeorgeTelford
Postby Chris C » Sun May 14, 2006 4:47 pm
Oops! :shock: Third time I've been wrong this year! :lol:
Chris :D
Chris C
Postby asianflava » Sun May 14, 2006 11:30 pm
For one of those small 2-stroke engines to work, they have to be running at full bore. I don't think people would appreciate a weed eater engine running at full throttle anywhere near their campsite.
asianflava
