Very inexpensive camper fan
Postby EZ » Fri Apr 21, 2006 4:58 pm
I grabbed this 10" fan at Wally World today to check it out. It is an Ozark Trail portable camping fan. Supposed to run on 8 D batteries (12 volts). I connected a 12 volt plug to it for a test. It works absolutely great. Has 2 speeds and is not loud at all yet moves plenty of air on either speed. It folds for storage or hanging in front of a window or sets on it's base. It could also be mouted sideways on a wall and folded out of the way when not in use.
I checked the current draw with a digital meter and it draws .46A on low and .65A on high. I was impressed. I was going to use computer fans but this is way better.
Best part: $13.88. :)
EZ
EZ
Images: 54
Postby madjack » Fri Apr 21, 2006 5:02 pm
coooool(pun intended) :thumbsup: :thumbsup: ............................................. 8)
p.s. it looks like it could modded easily to blow in/out a roof vent, giving you an effective(affordable) alternative to the FanTastic fan..........
Postby Rob » Fri Apr 21, 2006 5:14 pm
EZ--
How do you connect a 12V plug to it? Does it come with that option or is it something you had to modify?
Rob
:wine:
:peace:
Rob
Images: 58
Postby Miriam C. » Fri Apr 21, 2006 5:25 pm
So---what he said---
This could be great for pets. You wouldn't need to hard wire it and they would be safe.
Miriam
Postby Chip » Fri Apr 21, 2006 5:32 pm
dang it ,,, now I got to go spend some more money at wally world,,, thanks for the tip though,,,,
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby neal b » Fri Apr 21, 2006 6:05 pm
i am on way to wal* mart to get mine $>
neal b
Postby EZ » Fri Apr 21, 2006 6:20 pm
This fan is supposed to run for 24 hours on 8 D cell alkaline batteries. I think I will load it up with batteries but stick a cardboard tab on one end of the battery and run off 12 volts. Then if my deep cycle dies on a really hot night I can remove the cardboard tab and run on D cell back up. This thing is made for teardrops!
How do you run it off of 12 volts? Buy a cord and plug it in. It has a 12 volt input. This post is edited since Walter pointed that out.
I think MadJack is right, if this thing turns out to work OK horizontally I will try to modify one to go in my roof vent.
Per the instructions
Product note: To extend the life of the product, please turn off the fan when not in use.
:? :yes: :no:
Ed
EZ
Images: 54
Postby DANL » Fri Apr 21, 2006 6:33 pm
I saw a similar item at Target. From Coleman, I think. Will probably get one for my trailer.
How about putting rechargable batteries into it and then installing a Harbor Freight 12 volt solar charger on the roof to keep it charged?
Some links...
http://www.walmart.com/catalog/product. ... id=4767725
http://www.walmart.com/catalog/product. ... id=4744668
The tiny trailer in the avatar is designed to carry our recumbents and sometimes sleep in. We LOVE having a kitchen in the woods and a place for most of our gear.
Dan Jones http://sunsetlanding.com/teardrop/teardrop_intro.html
DANL
Postby surveytech » Sat Apr 22, 2006 3:30 am
EZ wrote:This fan is supposed to run for 24 hours on 8 D cell alkaline batteries. I think I will load it up with batteries but stick a cardboard tab on one end of the battery and run off 12 volts. Then if my deep cycle dies on a really hot night I can remove the cardboard tab and run on D cell back up. This thing is made for teardrops!
How do you run it off of 12 volts? Well first you need a 12 volt plug with a cord. I had one laying around that is 10 feet long but they are about $4 at Walmart. Drill a small hole in the battery compartment and feed the wire through it. Solder the wires to the + (red) and - (black) terminals in the case and viola: 12 volt fan. Really simple
I plan on going to Radio Shack and getting a plug and socket and mounting the socket in the side of the battery compartment so that I can disconnect the cord for storage.
:? :yes: :no:
Ed
EZ........looking at that second photo, isnt that a jack installed at the bottom of the fan case? So you could just plug it in?
I saw this fan too and for some reason I thought there was a jack on it.
You are right. It is a very good buy!
Walter
surveytech
Images: 6
Postby davel » Sat Apr 22, 2006 7:34 am
EZ,
That's a great little fan. We've been using ours for about a year now. When you plug it in to 12 volts it disconects from the batteries. Ours had an adapter plugin hole on the side of the fan, didn't need to do any modifications to plug in the 12 volts.
We just got an adapter plug from Radio Shack and wired it to Cigarette lighter plug. :thumbsup:
davel
Images: 32
Postby Arne » Sat Apr 22, 2006 10:17 am
Did a search, price is much higher.. will have a look next time I'm at w/m.....
http://tinyurl.com/q7btp
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby EZ » Sat Apr 22, 2006 11:38 am
A 12 volt input. Oh man, I didn't even see that!!! :scratchthinking: Nice Walter. I was so busy connecting it to my battery to see it work that I completely missed it. That is so sweet. There, now I retract my post about making it a 12 volt fan. New procedure: Buy a cord and plug it in.
Ed
EZ
Images: 54
Postby ALAN GEDDES » Sat Apr 22, 2006 11:38 am
I picked one up to keep the dog cool in thr truck and will probably get another for tear use. Very quiet and mooves a fair amount of air. With my 18V/dc power supply in tear it should crank out a few more rpm.
Alan
ALAN GEDDES
Images: 34
Postby EZ » Sat Apr 22, 2006 12:03 pm
The company that makes this fan has a website with a store locator at:
http://www.o2-cool.com
ImageRadio Shack
Ed
EZ
Images: 54
Postby Artificer » Sat Apr 22, 2006 6:56 pm
Just got back from Wallyworld. They have 2 versions of the fan. The first I saw was in the fan/AC section, with the O2 Cool logo. It comes with a 120VAC-12VDC wall wart. The second was in the camping gear, with the Ozark Trail logo, and the O2 Cool logo smaller on the package. I believe both were battery powered, as well as having the 12DC socket. Ozark Trail version has a drop down foot, which is where its batteries are stored. One was $12.89, and the other $13.89.
I picked up the Ozark Trail version.
I was also looking at the Trunk Box that has been mentioned previosly. I saw a larger box that would work on my trailer tounge. 36" wide, deeper and taller than the trunk box, but going for $44. I think I've found whats going on the front of my trailer.
Artificer
Images: 16
