Shorepower inlets anyone?
Postby Steve Frederick » Thu Apr 27, 2006 9:53 pm
I'm looking for a 120-volt 15-20 amp inlet that would fit-up to the side of the T/D.
Any sources??
Thanx! ;)
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Re: Shorepower inlets anyone?
Postby Kevin A » Thu Apr 27, 2006 10:01 pm
Steve Frederick wrote:I'm looking for a 120-volt 15-20 amp inlet that would fit-up to the side of the T/D.
Any sources??
Thanx! ;)
I got mine at bass pro shops. (click on photo)
Kevin A
The other guy
Images: 289
Postby sdtripper2 » Thu Apr 27, 2006 10:04 pm
Up at the top
http://www.mikenchell.com/tttt.pdf = Rich's list
page 17
sdtripper2
Search Garoux
Images: 168
Postby stedi » Thu Apr 27, 2006 10:05 pm
west marine has'em too.
the government does not produce one single bushel of corn, one single barrel of oil, or one unit of any other commodity. the only way it obtains the money that it awards to its chosen recipients is by taking it from others who earned it. this is called "voluntary taxation".
stedi
Postby IndyTom » Thu Apr 27, 2006 10:06 pm
Something like this?
West Marine
Can someone remind me where to find the Tiny URL thingy? :shock: [/img]
Tom,
If you use edit to check the changes I made, you can shorten your url's easily.
Never trust a skinny cook
IndyTom
Images: 42
Postby madjack » Thu Apr 27, 2006 10:09 pm
those power inlets can be had at Waytekwire.com for around 15 bucks and at Academy Sporting goods for around 10...
Postby Kevin A » Thu Apr 27, 2006 10:10 pm
Bass pro shops price $12.99
Kevin A
The other guy
Images: 289
Postby Bigwoods » Thu Apr 27, 2006 10:54 pm
I found one at a junk yard for $2.00.. It is the block heater plug in on Taurus and Sable. It is found under the grill. Mine came off a 1996 Sable.
Greg (Bigwoods)
Greg in Northern Minnesota
Bigwoods
Images: 104
Postby bdosborn » Thu Apr 27, 2006 11:40 pm
I used this:
Hubble HBL61CM64 ~$25
I got it from the local Greybar outlet.
Images: 466
Postby Ira » Fri Apr 28, 2006 5:10 am
I got the similar item at West Marine, Marinco Brand, for only twice the price, Bruce! 30 amp.
EVERYTHING is more expensive at the marine store, but for this, maybe there's a reason--it's built for heavy salt water exposure.
One caveat about the Marinco though which I posted before:
You can't go to a box store and get a similar connector for it from another company. Marinco "depths" the two parts to only work with each other.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby BILLYL » Fri Apr 28, 2006 5:14 am
I made one - looks very similar to the one above. Some PVC, JB Weld and your off and running
Bill
"If your children ever find out how lame you really are, they'll
gonna murder you in your sleep...." Frank Zappa
BILLYL
Postby Sonetpro » Fri Apr 28, 2006 5:23 am
Ira wrote:I got the similar item at West Marine, Marinco Brand, for only twice the price, Bruce! 30 amp.
Ira I got one like this http://www.marinco.com/scpt/ProdPage.ph ... e%20Power#
I went to Lowes and got a 30A twist lock. No problems.
Maybe you were trying a 20A in the 30A. A 20A sure won't fit
Sonetpro
Images: 107
Postby surveytech » Fri Apr 28, 2006 6:02 am
I am using the one from bass pro as well.
seems to work well.
surveytech
Images: 6
Postby cracker39 » Fri Apr 28, 2006 7:28 am
Most of those connectors pictured are 15 amp. The 30 amp connectors are harder to find and more expensive. To keep the cost down, and in keeping with KISS, I just put a cord hatch in the side of my tongue box, cut the socket off the cord, and hard wired my cord end into my main breaker box. I lost less than a food of cord length by doing this instead of using a connector. I left enough wire on the socket that I cut off so that I can put a 15 amp plug on it to use it for an adapter to connect to a 15 amp outlet if 30 amp isn't available.
I know someone is going to ask why I have expopsed wires in the box, so I'll explain before you do. The exposed wires you see running from the breaker box will be put through conduit from the breaker box to the converter in the galley before all is said and done. I just hooked them up temporarily to test the system. The cable running into the piece of PVC pipe in the lower left of the pic on the right goes to my running lights connector to the truck. the cable comes out of the cabin, into the PVC, then into metal conduit welded to the tongue where it comes out just under the coupler.
Dale
cracker39
Images: 233
Postby Ira » Fri Apr 28, 2006 7:52 am
Steve, I got this one, but the standard connector from HD wouldn't fit:
http://www.marinco.com/scpt/ProdPage.ph ... creational
Here we go again!
Ira
Forum Storyteller
Images: 118
