Galley Hatch Hinge
Galley Hatch Hinge
Postby Gary T » Mon May 15, 2006 12:02 pm
I know this is a stupid question but does the galley hatch hinge need to be cut to the outside edge of the trailer.
Why I ask is that my trailer is 4' 1 1/2"s wide. 4 feet plus the 2 3/4" outside walls.
I just need to order my hinge and dont know if I should go 4' or 5'
Help
Gary T.
The mind is like a parachute. It works much better when open.
Gary T
Images: 7
Postby Chip » Mon May 15, 2006 12:10 pm
just my opinion but order it longer and cut it to fit,,, you will want the hinge to funnel water off to the side and if its cut short then the crack on each end has to be filled in with something ,,, just something to engineer if its too short,,,
chipper
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby Sonetpro » Mon May 15, 2006 12:25 pm
Mine overhangs 1/2" on each side.
Sonetpro
Images: 107
Postby Gary T » Mon May 15, 2006 1:03 pm
Thanks for the fast reply.
I was just trying to be cheap and order the 4 footer.
Cheap usually is the wrong choice.
I guess 5 feet it is.
Gary T.
Gary T
Images: 7
Postby rainjer » Mon May 15, 2006 2:05 pm
Are you getting it from Grant @ LilBear? If so, email him you trailer width & he may sell you a 4 footer & just cut it long. It does not hurt to ask.
rainjer
King Koleman
Images: 11
Postby Gary T » Mon May 15, 2006 2:32 pm
Thats where I was going to get it.
I will email him and ask.
Like you say it cant hurt.
Thanks again
Gary T.
Gary T
Images: 7
Postby Joanne » Mon May 15, 2006 2:52 pm
Hi all,
On the same topic but a slightly different question; Did you all put sealer under the hinge section that attaches to the trailer? I'm getting ready to install the trailer side and started to think that water could get under the hinge and drip into the galley. I am thinking of using the same putty as I used for the roof vent and front window.
Joanne
New! My Camp Cooking Forum
Project Desert Dawg website
Universal Health Care
Joanne
Queen of Cast Iron
Postby TomS » Mon May 15, 2006 6:12 pm
Joanne wrote:Hi all,
Joanne
I laid down a thick bead of caulk before installing my galley hinge. I fabricated these rain diverters to help keep water out of the galley.
Tom Swenson
[email protected]
TomS
Postby Sonetpro » Mon May 15, 2006 9:16 pm
Gary T wrote:Thats where I was going to get it.
Thanks again
I got mine from him When you order it just tell him the width of the roof he'll tell you what to order. I told him mine was 63" he emailed back that I would need a 64" and that's what he sent me. I got it 3 days after ordering it.
Sonetpro
Images: 107
Postby Boodro » Mon May 15, 2006 9:54 pm
Joanne , yes you will need to seal under the hinge on the top. I forgot to do mine at first & went camping & it RAINED , water poured into the galley under the hinge! :oops: Learned a lesson , double check yoour work br for moving onto the next step! :roll: I used a bead of self leveling caulk to seal it. Does not leak NOW! :applause: :applause: :applause: Good luck!
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Postby Joanne » Tue May 16, 2006 10:44 pm
Tom,
Thanks for the picture on those diverters. I'm going to need to make something like that for me as well.
Joanne
Joanne
Joanne
Queen of Cast Iron
Postby Joanne » Tue May 16, 2006 10:46 pm
That's exactly what I was concerned about!! I'll be sure to apply the sealer when I install it.
Thanks!
Joanne
Boodro wrote:Joanne , yes you will need to seal under the hinge on the top. I forgot to do mine at first & went camping & it RAINED , water poured into the galley under the hinge! :oops: Learned a lesson , double check yoour work br for moving onto the next step! :roll: I used a bead of self leveling caulk to seal it. Does not leak NOW! :applause: :applause: :applause: Good luck!
Joanne
Queen of Cast Iron
