Wall to Floor Seal?
Wall to Floor Seal?
Postby Bandit » Sun May 21, 2006 12:33 pm
I have just completed my walls and am in the process to mount them to the floor. I am using pocket screws (21 per side) to secure the wall to the top of the floor surface. What have you guys used to seal the wall to the floor? (Glue, tub & tile seal, epoxy, silicon?)
Thanks!
:thinking:
First Metal Cut 02/11/06
Complete! (Almost) 08/22/06
Looking for a trip in the SPRING!!!!
Not Up to Testing the Heater!!!
Thanks for all the HELP!!!!
Bandit
Postby Sonetpro » Sun May 21, 2006 12:56 pm
I used Gorilla glue. When it foamed it made a good seal. Just had to go around the edges with a sharp wood chisel after. to clean up the foam that sqeezed out.
Sonetpro
Images: 107
Postby halfdome, Danny » Sun May 21, 2006 3:00 pm
Sonetpro wrote:I used Gorilla glue. When it foamed it made a good seal. Just had to go around the edges with a sharp wood chisel after. to clean up the foam that sqeezed out.
Same here. Cured Gorilla Glue scrapes off very well with a sharp chisel.
8) Danny
halfdome, Danny
*Happy Camper
Images: 171
Postby Bandit » Sun May 21, 2006 10:07 pm
Will the Gorilla Glue seal the edge between the wall and the floor or did you also use a silicon to seal the edges?
:thinking:
Bandit
Postby asianflava » Mon May 22, 2006 3:14 am
I don't think it will because Gorilla Glue is porous, I could be wrong though.
I didn't seal my floor to the sidewall. I just used polyurethane caulk to glue them together and screwed them. I then made shure the asphalt covered the joints when I applied it to the bottom.
asianflava
Postby Sonetpro » Mon May 22, 2006 6:31 am
Rocky, actually only the foam out is pourus. When you glue wood with it the wood will break before it let's go. and it is waterproof.
Sonetpro
Images: 107
Postby Todah Tear » Mon May 22, 2006 9:25 am
I used liquid nails. Between my walls and floor edges.
Todah
Todah Tear
Images: 282
Postby IndyTom » Mon May 22, 2006 10:41 am
Im using PL Premium in every joint. :thumbsup: :thumbsup:
Never trust a skinny cook
IndyTom
Images: 42
Postby Cutterpup » Mon May 22, 2006 8:04 pm
Seal I was supost to seal the joint? :thinking: :thinking: I just glued the plywood to the 2x2's.
It's been over a year and no problems :relaxing:
As I have said over and over
Its a trailer quit over building it
Dan
Cutterpup
Images: 15
Postby Steve_Cox » Mon May 22, 2006 9:03 pm
TOO LATE, I OVER BUILT IT..... :lol: :lol:
Used thickened epoxy in the joint and coated the outside with it too. I forgot it wasn't a boat.
Steve 8)
Steve_Cox
Images: 196
Postby doug hodder » Mon May 22, 2006 9:08 pm
Me too Steve...thickened epoxy...had it left over from a boat project...Doug
Postby jplock » Tue May 30, 2006 9:34 pm
Here is how I did mine. I used titebond 3 glued clamped and put screws through the 1/2" plywood floor and to the frame. I tightend it untill I could see no light between the wall and floor. Also notice that the glue squeezed out. I just did this just this evening. Also I coated both surfaces of the joint with a smooth coat of glue and spread it evenly with my finger.
jplock
Keep smiling!
jplock
Images: 233
