# coals=Degrees and cooking times?
Postby Micro469 » Tue May 23, 2006 10:44 pm
I know somewhere in these threads someone posted a chart on how many coals you need for a certain temp depending on you DO. If any one knows where it is, maybe Mike can put it in the Important Information forum so that Us with poor memorys can refer to it once in a while. It's great to say to cook something at 350* but if you don't know what it takes to get a DO to that temp, Then all is in vain..... Help Anyone??? :oops:
John
Micro469
Images: 382
Postby Ma3tt » Tue May 23, 2006 11:03 pm
some say Take the number of inches of the oven put 3 coals less then the number of inches under and 2 over the number on top so a 12" oven would have 9 under and 14 on top. Some say it's 25 degrees per coal, well with that logic if you only put one coal on you could make ice cream :lol:
Be Good
1967 Siesta del Sobrino "Standy"
If you lived here... you would be home by now.
http://www.Camp-Cook.com
Ma3tt
Dutch Oven GURU
Images: 179
Postby rainjer » Tue May 23, 2006 11:07 pm
rainjer
King Koleman
Images: 11
Postby Aussie Nomad » Wed May 24, 2006 12:34 am
The link was. http://www.uglybrothers.net/RECIPES/dutchoven.htm
I can't remember the thread either.
Ian. :D
Edit: I found the thread. http://www.tnttt.com/viewtopic.php?t=8868
Ian. :D
Aussie Nomad
Postby Kurt (Indiana) » Wed May 24, 2006 5:39 am
Ma3tt wrote:some say Take the number of inches of the oven put 3 coals less then the number of inches under and 2 over the number on top so a 12" oven would have 9 under and 14 on top. Some say it's 25 degrees per coal, well with that logic if you only put one coal on you could make ice cream :lol:
That's my formula as well. It works well on all my 8" and on the 12" :thumbsup:
The cooking time "keeping the lid on" (not peeking) helps a lot. :thinking:
CRA 2021 Maps
CRA2021 Web Site
"Wall of Fame 2011-2021"
Kurt (Indiana)
Re: # coals=Degrees and cooking times?
Postby Mike B » Wed May 24, 2006 9:21 am
Micro469 wrote:I know somewhere in these threads someone posted a chart on how many coals you need for a certain temp depending on you DO.
A chart is a good place to start, but you have to learn how to adjust the heat from there. The temperature of a Dutch oven is affected by
    Outside temperature
    Amount of wind
    Humidity
The number of coals used top and bottom is also affected by what you are cooking. If you are baking, you need to adjust the number of top coals upward and the bottom coals downward, so the food will be browned correctly. (If you are baking, don't forget to rotate the lid and the pot every 10 minutes or so to prevent hotspots from burning the food).
Some of the recipes I have posted on my web site have recommendations for the number of coals to use, but that assumes you are cooking on a calm day of average temperature. As we all know, there is hardly any such day, so I now just give temperatures in degrees.
BTW, for more good DO recipes, check out http://www.iedos.org/
Mike
Hayden Lake, ID
http://www.blogicalthoughts.com/
Mike
Hayden Lake, ID
Mike B
Postby Kurt (Indiana) » Sun Jul 09, 2006 2:40 pm
I tried the "flour" experiment today to see what combination of coals is right for my 8" DO.
http://www.buckskin.org/Resources/Outdo ... h_oven.htm
At 350 degrees, the flour should turn "light brown". The coal arrangement I used was 8 (top) and 6 (btm). It worked, but I started with only 6/4 combination. The 6/4 was too cool so I turned up the heat and waited another 10 minutes.
The charts that are published are good starting points, but a good temerature test is worth the effort.
CRA 2021 Maps
CRA2021 Web Site
Kurt (Indiana)
